Question about LG DLE7177 Dryer
Dryer I just bought a slightly damage dryer its a tromm LG dryer wild cherry in color when you spin the drum it is hitting on the side of dryer they are comming out monday to fix it but today is friday I need it fix now!!!!! how does the top come off I,mm pretty handy ,the metal needs to be push out just a little it would be fine john
  • Anonymous Mar 18, 2008
    Just like John, we have a dryer that we bought a little over a year ago and the drum hits the side and makes a banging noise. It looks as if when the drum turns it separates and causes the drum to bang against the side. Any help would be appreciated.
    Is there a reason why the warranty is only a year? Is that industry standard?
  • 489 Answers
The top comes off by removing the 2 screws in the back the hold the lid.  Push the lid back and it should come off.
Posted on Apr 28, 2008
My lg tromm washer sudenly started making a grinding sound and the drum does not spin. What is wrong?
You don't say whether the drum turns freely by hand.
It could be a broken spider or a seized or broken bearing or something come adrift in the tub causing it to jam.
The top will need to be removed for a closer inspection and it might be a simple and quick repair but from your description it will probably be absent from your home for a day or three and cost quite a lot.
Mar 01, 2015 | LG Tromm Front Load Washer And Dryer Set
Lg tromm wm1812cw dum makes load noise when spinning
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm DLE5977 won't start the tumble
Sounds like loose belt. If the drum spins by hand, it's almost guaranteed to be a bad belt.
Nov 27, 2013 | LG DLE5932W Electric Dryer
We have the LG Tromm DLE2512W dryer. It was working great until one day it sounded like a big thud, and the drum stopped spinning. We can turn it on and set and start it, but the drum isn't spinning at...
It is your belt that has broken and will not allow the drum to spin, you need to replace your belt on the dryer. I do not have instructions for your dryer, but maybe the instructions for another dryer will give you the idea how to fix your, it is normally an easy fix.
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 07, 2011 | LG Dryers
Loud thumping noise has resulted in penny size hole in the drum.
Check your owner manual some LG had life time warranty on there drums..if so call for service..
Sep 21, 2009 | LG DLE3777 Electric Dryer
My LG TROMM DLE7177 on heating cycle finish much quicker
First off, unless you are using the manual dry (timed dry) option, the times listed are strickly an estimate. At the begining of a cycle, the dryer has no idea how big a load you have, how wet it is, and how good your vent is. In your situation, I would clean off the two silver colored moisture sensor bars, located just inside the drum, by the right side of the lint filter area. They are curved, about 5 inches long, and about an inch apart. If you use fabric softener sheets, they can aquire a waxy build up, which inhibits them from detecting that the clothes are still too wet.
Aug 27, 2009 | LG DLE7177 Dryer
Drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Bought cherry lg tromm dryer, bf ruined the gas line hook up (tried to fit the wrong size hose) can this be fixed and what can we do?
if the threads are ruined on the dryer unit itself, id reccomned calling in an lg authorized repairman. if it has to do with gas line installation go with a liscenced plumber.. why mess with GAS in home.
Mar 04, 2008 | Dryers
LG Tromm Electric Dryer
NO it is not normal if it is only that old ....I would Call LG service it will still be under Warrty..(unless you are drying ball bearings)
Good Luck
Feb 16, 2008 | Dryers
LG DLE7177 Dryer Logo
119 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
