Question about Sony Ericsson K750
One of the left select KEY of mobile is broken. where to get case / panel
    Problem Solver:
  • 7 Answers
Buy
Posted on Jul 03, 2009
How do I text with Samsung Gusto 3 flip phone.
Create and Send a Text Message - Samsung Gusto™
  1. From the main screen, press the left soft key to choose Message.
  2. Select New Message then press OK.
  3. Select TXT Message then press OK.
  4. Enter the desired 10-digit mobile number(s) or email address(s) then press OK.
  5. Enter the message.
  6. To add a graphic, animation or sound:
    • Press the right soft key to choose Options.
    • Select Add then press OK.
    • Select a category (Graphic/Animation/Sound) then press OK.
    • Select an item then press OK.
  7. Press OK to choose SEND....
  8. try this.
Nov 22, 2016 | Samsung Cell Phones
24:10 code error
The system error 24:10 is a critical error in which the printer cannot be used until has been corrected.
Turn the printer on in Diagnostic Mode. Turn On the printer holding down Power + Cancel + DOWN buttons until you hear one beep before releasing ALL three keys.
Note:This could take few attempts to find correct timing on holding the buttons down, remember to hold the down key and cancel key and then hold the power button key so all 3 buttons are pressed until bleep at 5 seconds then release. Each attempt you have to wait for boot up to see if it powers up to the below diagnostics menu.
Scroll down to "Service Special Utilities" and select OK
Scroll down to "Bag Broken Recovery" and press OK to start the process.
Note: This procedure will only help if problem is just with a ink carriage just been fitted in the last 6 hours.
The front panel will display a series of questions which you answer Yes or No depending on the status of the printer. Use the Up and Down arrow keys to select Yes/No and the OK key to confirm the selection in each case.
Remove the Ink Cartridges and check for any ink leaking from the cartridge. In extreme cases ink
can contaminate the ISS PCA area which will then require instalIing a new ISS PCA.
If the message 'Please replace one of the defective cartridges (*). The asterisk represents a
number which will identify the failed ink cartridge.
Number displayed Ink Cartridge Color Failed
0 Magenta
1 Light Magenta
2 PhotoBlack
3 Matt Black
4 Yellow
5 Light Cyan
6 Light Gray
7 Cyan
  • Question 1:'Are the Tubes from the Air Pressure System (APS) to Ink Supply System (ISS) Clean?' YESIf the tubes are clean of ink select the Yesoption. However if the tubes have sections of tubing that have ink in them, select the Nooption and replace the Tube assembly.
  • Question 2: 'Do tubes from the ISS to Carriage contain visible air?' NOIf the tubes between the ISS and the Carriage Assembly do not have air bubbles, or clear sections of ink tubes where air is present mixed with ink, select the No option. However if you can see air in them, select the Yes option and replace the SRK assembly.
  • Question 3: 'Do you want to remove the broken bag condition?' YES At this question select the Yes option to clear the broken bag error.
To finish the procedure select any key on the Front Panel and the printer will shut down.
Insert the new Ink Cartridges into the printer and turn On the printer.
Note: If the Tube assembly needs to be replaced, the Broken Bag Recovery procedure will still need to be performed after they have been replaced.
If you need any more help or service please contact 1st Call 4 Service Ltd.
Feb 15, 2014 | HP Designjet Z6100 InkJet Printer
Unfortunately my mobile language is change to Hindi . i don't know Hindi .how can i change to English.i don't have user guide
First Open Menu(Center key)>>press Down1 time (Scroll key down) >>Press Left 1 time (Scroll key left)>>Select (center key)>>Press Down Key 10 times>>Select(Center key)>>Select(center key)>>Select (Center key)>> Press UP 1(scroll key up) and press center key.Try this ,I think this will helpful to you.Good luck Thanks for visiting fixya
Sep 21, 2011 | Nokia 2730 Cell Phone
I want to delete the contact in my LG GS290 mobile
Have a nice day.
Here are the ways to delete the contact/contacts in your mobile phone:
From the main menu screen, press Contacts [Right Soft key].
Press Options [Right Soft key].
Select a contact from the contacts list.
Press the Right Soft key for options.
Scroll to Manage Contacts, press OK
Select Erase, press OK.
Press Right Soft key to select all or select desired contacts to erase by pressing OK to mark each contact.
Press Left Soft Key for Done.
Display shows Erase Contacts?
Select Yes, press OK.
Hope it can answer your question,
Thank you for using fixya.
Adieh
Sep 12, 2011 | Cell Phones
Want to unlock and my sim are broken
Don't worry about broken Sim card...While Unlocking You no need Sim card,so after Unlock it You can buy new sim card,So you need to specify the NETWORK and Country it locked now.Get the Unlock code from here
Superunlockcodes.com and Unlock instructions from here
Mobileunlockguide.com and Unlock it step by step,
Unlocking instructions:
Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson C902 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson C902 without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
Sep 05, 2011 | Sony Ericsson Cyber-shot C902 Cellular...
How setup internet settings
You'll need to complete all steps for this to work.
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this. The Navi key can also be pressed in to select options.
1. Press the 'i' button (press navi key).
2. Highlight 'Browser' and press 'Select' (left softkey).
3. Highlight 'Browser settings' and press 'Select' (left softkey).
4. Press 'Options' (left softkey) , highlight 'Add new connection' and 'Select' (left softkey).
5. Highlight 'Profile Name' and enter 'giffgaff GPRS WAP'
6. Highlight 'Homepage URL' and enter 'http://giffgaff.com/mobile'.
7. Check that 'Proxy' is ticked (press Navi key to tick/untick).
8. Highlight 'IP Address' and enter '193.113.200.195'.
9. Highlight 'Port' and enter '8080'
10. Ignore 'Linger time' (this is preset at 90).
11. Check that 'DNS' is unticked (press Navi key to tick/untick).
12. Highlight 'Bearer' and select 'GPRS' by pressing the Navi key right or left.
13. Highlight 'Advanced settings' and select using center Navi key.
14. Highlight 'APN' and enter 'giffgaff.com'.
15. Highlight 'Login ID' and enter 'giffgaff'.
16. Highlight 'Password' and enter 'password'.
17. Press 'Save' twice (left softkey).
18. Highlight 'giffgaff GPRS WAP' and press 'Options' (left softkey)
19. Highlight 'Activate' and 'Select' (left softkey).
20. Press 'Back' (right softkey) 3 times to return to the main screen.
The GPRS WAP settings are now complete.
Dec 21, 2010 | Samsung SGH-J600 Cellular Phone
How to check wap profile in my s3500 mobile?
1. Press 'Menu' (Navi key).
2. Highlight the 'Settings' and 'Select' (left soft key).
3. Highlight 'Application settings' and 'Select' (left soft key).
4. Highlight 'Browser' and 'Select' (left soft key).
5. Highlight 'Browser profiles' and 'Select' (left soft key).
6. press 'Options' (left soft key).
7. Highlight 'Add new connection' and 'Select' (left soft key).
Nov 11, 2010 | Samsung S3500 Cell Phone
How can I adjust the screen wobble on a alienware aurora m9700 laptop.
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
May 29, 2010 | Alienware PC Systems Alienware Aurora High...
Locked
you may try the following tips.....
Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson Z300A mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson Z300A mobile phone without any SIM Card,
If your Sony Ericsson Z300A mobile phone does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
Feb 06, 2010 | Sony Ericsson Z300a Cellular Phone
My mobile network connection keeps disconnecting. I turn it back on but when i leave the connection screen it turns the radio off, is this fixable?
In this case you need to follow certain trouble shooting step's:-
1) Go to Option's.
2) Select mobile network.
3) Then press menu key.
4) Select Diagnostics test.
5) Then press menu key again.
6) Select Run
You will get Radio data activation.
I hope I was able to help you.
Thank you for using Fixya.
Oct 12, 2009 | RIM BlackBerry Pearl 8100
Sony Ericsson K750 Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
