Question about iLO 3200 32 in. LCD Television
Ilo-32hd Is there a reset button inside the set to unlock all functions on this set such as 'channel up/down, vol up/down, source, etc...
  • 26 Answers
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
Posted on Jan 22, 2008
i have the same problem too. got a number at Walmart and ask to call this number directly: Intial Tech Corporate office: 909-392-5583
Posted on May 14, 2008
  • 4 Answers
SOURCE: ilotv 32HD
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't throw good money after bad and don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Posted on Sep 27, 2008
SOURCE: ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Posted on Sep 29, 2008
  • 331 Answers
SOURCE: no function control at all just only on/off
i hope this number works
i got it from walmart
Posted on Oct 25, 2008
  • 7 Answers
SOURCE: ilo-32HD Main PCB Assy has a few for around $150.00, just make sure the revision #s match or eStoreGEX has listings on ebay to rebuild your existing PCB for $94.00
enter your pcb # in the eBay search i.e. MLT169B
Posted on Apr 01, 2009
0 characters
1 Points
I have ILO-32HD set. Wide black lines top and bottom of picture. How to remove?
Its not the set if only two channels---it does not know what channel you are on===you are describing a non problem--
May 30, 2012 | iLO 3200 32 in. LCD Television
I have an ILO 32HD and the HDMI input does not seem to work.. goes from no signal to HDMI 10801 but i get a flash of a picture somtimes.. My first HD and can't see it!!! I have tried 2 NEW HDMI cables...
HDMI issues are almost always the scource and not the TV. If HDMI fails to work then use the component inputs as your picture will still be in high definition when on HD channels..
Nov 11, 2009 | Flat Panel Televisions
TV won't power up
Likely a failed fluorescent backlight or the inverter that supplies the high voltage to it. I'd like to suggest a potential source for parts or service but the earlier authorized service company was Initial Technology and their webiste is no more so the company is probably defunct. Ilo was sold only by Wal-Mart and our 32HD failed after 6 weeks and when returned after several weeks from repair, had the LCD panel damaged which didn't show up until we tried using it full screen and saw the flaw.
You may have some luck here:
Possible Ilo parts source
Otherwise, I'm afraid your friend is just another victim of a Wal-Mart junk supplier.
Aug 18, 2009 | iLO 3200 32 in. LCD Television
Cracked lcd trying to buy a ilo-32 hd lcd
You do know that the LCD display will be a few dollars short of a new set ? If your still interested in it then let me know.
May 20, 2009 | iLO 3200 32 in. LCD Television
Who can I call to get technical support of Ilo-32HD?
If your tv has a cable jack (screw on/in cable tv cuplink), it is then digitally abled. - Hope this helps.
Mar 15, 2009 | iLO 3200 32 in. LCD Television
Ilo 32HD NO Channels! buzzing noise
the input setting may need changed on your tv
Dec 09, 2008 | iLO 3200 32 in. LCD Television
Normally this is a good indication of a stuck button on the set. With the set off, try working each of the control buttons. You should be able to feel teh button engage. If one feels like it does not work, that is the likely culprit and it should be replaced.
Let me know your results.
Sep 07, 2008 | Flat Panel Televisions
Ilo-32hd tv only 1 chanel
Aug 16, 2008 | iLO V27DMBX Television
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
I recently bought an ILO 32 HDTV with the same problem. I searched every site I could find for a solution. I finally found someone that gave me the direction to replace the Main Board for the TV. This is the board that you can plug your exteranl devices into, computer, dvd, HDMI etc.
The phone # to Digital Age is 909-974-2859. These are the people who can send you the part you need. Also the remote that I have is RC-500, which is the newest remote control for the new Main Board. I would suggest getting this remote.
The price of the board was $123.89 with $10.00 shipping. It only took 4 days to get the board from Ontario California, and yes they do speak english.
I removed the backpanel myself and then removed the metal cover over the Main Board. Remember to mark all of your wires and screws so you can put them back in the same location. The connections are all quick disconnects and the board is one piece. I had the board replaced and the back panel back on within an hour. All buttons working on the TV and the remote control, and the TV is working great with sound.
But I do not have the Manual......does anyone have the manual? I am willing to help anyone with a fix for their TV for a copy of the TV Manual.
I hope the information I have given helps in anyway possible,
Aug 08, 2006 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
81 people viewed this question
Top iLO Flat Panel Televisions Experts
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Flat Panel Television Expert? Answer questions, earn points and help others
