Question about Casio Exilim Pro EX-P600 Digital Camera
No Flash! Is there a bulb inside that burned out? How to buy and replace it? Still takes great daytime shots but no inside ones without a working flash. Please email
  • 1 more comment
  • Mrqcace Nov 11, 2007
    Same problem, no flash. All other shots were well. Red indicator light flashes quickly, indicating flash is not charging. Battery is good.
  • melchious Dec 31, 2007
    hi my name is gibson from mumbai . my problem is that the flash is not working is there any way i can replace it in mumbai......... and if u can answer my problem plzzzzzzzzzz mail me on this id
    i have tried clicking sum snaps but all in vain all pics are so dark that v can't c whose sanp is that
  • Anonymous Jan 13, 2008
    I have the same problem. Red charging light flashes fast and constantly. Still takes great pictures in daylight. I've had my P600 for a little over 3 years. I'll try contacting Casio and ask about fixing it.
Mine had the same problem, I sent it back, they had to change out a circuit board, cost $97.00
Posted on Dec 16, 2007
I have a 1998 lincoln continental I can't figure out why only the front left front turn signal doesn't work?
Does the 4 way flash part of it work? If not replace bulb but make sure you clean the contact inside the socket, the area touching the metal on the bulbs gets corroded from arching on all the time. Plus daytime running lights cause a draw too. Check wiring at socket for burning or if you have a volt meter check to see if the 12 volts alternates off and on with turn signal in postion and key on.
Nov 05, 2015 | Lincoln Cars & Trucks
1996 chevy suburban high beams work, low beams and daytime running lights don't. checked all fuses none blown, dont know how to check relays except to replace each one, one at at a time.
with a test light back probe the green wire behind the low beam then if test light on = bulb defect
the blue one is for daytime running lights example : if 1 bulb is burn or open no daytime running lights
p.s. you need to have 2 bulbs the same or it won't work
Aug 05, 2013 | 1996 GMC Suburban
Sony DSC-H2 flash bulb not working
Probably just a burned out bulb or a disconnected wire. Try taking it to a Radioshack and see if they can take out the bulb for a replacement. Shouldn't be that difficult to replace.
Feb 28, 2011 | Sony Cyber-shot DSC-H2 Digital Camera
My flash no longer works. When I press half-way down, the image on my screen looks as if the subject is lit up, but when I take the picture the flash does not work. Could the flash bulb be burned...
The bulb is most likely the problem, but it could be the high voltage capacitor that triggers the flash bulb, or possibly the transformer that charges the capacitor. I would bring it to a camera shop to see if the bulb replacement will do the trick.
Jan 14, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
Where is the Daytime driving Lamp relay located
follow the wires to the drl relay. It must be inline from the regular light switch to the headlamps. I have a 1990 Cadillac Deville that has an aftermarket module that controls the daytime running lamps, and it is mounted on the driver's side wheel well.
Some relays are found in the fuse box under the hood.
If your daytime running lamps burnt out, take it to an electrical shop and ask them to check it out.
If you buy an aftermarket daytime running lamp kit, they can install it for you.
But, I agree, you should check for voltage and function at the relay for the daytime running lamps on your Astro.
But, if all else fails, the electrical shop should be able to diagnose and repair this problem.
Jul 21, 2010 | 1999 Chevrolet Astro
My flash doesn't work...
1. Check the batteries
2. The flash bulb might be burn out and it could be replaced with a new one.
These two steps will help you in a solution the flash bulb can be replaced by any camera store.
Jul 17, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
The 911 flashing light on our lamp post does not work?
wow that seam's like a good one, you may need a 3 way bulb in the lamp post? thats the only thing i can think of without looking at it.
Apr 08, 2009 | Electrical Supplies
Nikon sb-27 speedlight appears stuck in standby mode
Buy a Yongnuo flash. They are great replacements and are inexpensive.
Dec 14, 2017 | Nikon Speedlight SB-27 TTL Flash
Flash flickers...
i honestly never came across anyone who had a flash replaced usually because most companys flat rate out of warranty repairs at 100-125 dollars-if it's a p series camera it sounds like the flash is dying or the battery is worn out and not supplying proper voltage to allow it to fully fire-i would consider buying a new w series w150 is great or 120- if battery is fine then flash is just shot-even old memory sticks won't work in new models so you also have to buy a new card
Jul 27, 2008 | Cameras
Flash button won't select mode.
you cannot set anything on auto mode! The camera sets itself automatically. try taking shot(AutoMode)in dimlit area or no light at all. If it's taking shots and flash isn't firing, your flash bulb is already busted! I suggest you buy a separate flash unit (they cost the same as replacing parts and service fee), a cheap one is comparable or works the same as the costly one, if you know how to set up on manual mode ( they call it compose or advance or creative mode!)
Sep 03, 2007 | Fuji FinePix S5000 Digital Camera
Casio Exilim Pro EX-P600 Digital Camera Logo
54 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
