Washing machine wont fast spin
Hotpoint aquarius wma56 will not fast spin is it the brushes
  • Washing Mach... Master
  • 4,655 Answers
Because I don't have your model number or brand I will let you know that this could be a series of things that could cause the problem. If your washer has a lock for the door and at the time of spin you smell plastic melting in the air then I believe this could be the problem. If your washer has an electrical smell of burning od the motor then the motor could have a bad run capacitor or defective windings. What ever the case you need to stop using the washer until the problem is resolved. Please tell me more about the problems and get me the model and make, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://sites.google.com/site/sublimeappliancerepair/Home Check out SublimemasterJWebster He will get you going. Thanks, please rate me , Sea Breeze
Posted on Jul 03, 2009
  • 82 Answers
Check brushes if they are fine then it will be the moter for a new moter try espares or ebay
Wont spin and the front indicator lights are going from pre wash to end in a night rider fashion
try checking ur door switch may also want to check the water pressure switch which signals the machine to go into wash after the fill cycle
Feb 11, 2015 | Hotpoint Aquarius WMA56 Front Load Washer
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Finding an instruction manual for a Hotpoint WMA56
Click on the link below to download instructions manual for your appliance:
INSTRUCTIONS FOR INSTALLATION & USE for the AQUARIUS RANGE WMA56
Do not forget to rate the solution.
Thanks.
Mar 02, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Machine takes in water then wont go any further
Main motor needed new brushes, all working well now.
Jan 16, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
189 people viewed this question
Top Washing Machines Experts
