Question about Samsung SCX 4521F All-In-One Laser Printer
Printer is problem ie printer jam
Printer is jam, no movement for any light and no one and many printers problem in district so, kindly me be give me solved problem .
by thiruvallur DEEO office,
  • 5,081 Answers
Yes. When removing a jam, it is never wise to "aggressively" remove the paper, as it can break switches, gears, etc. In the case of the machine you have, it will jam if the guides do not actually touch the sides of the page. You likely stripped out the slip clutch that drives the pickup and feed rollers. If the machine is less than a year old, I can get you one under warranty. Email me and I will try to get you one under warranty
Posted on Jul 03, 2009
  • INDIRA KUMAR
    INDIRA KUMAR Jul 11, 2009
    sir i want to say few things without saying the model no brand of your machine you want me to solve the problem , when i give a genaralised solution as per your generalised question you rate me very low this is really unfair for further help give your details of printer ot please rate me
Tally T2365 printer giving Hardware Alarm code is +0001 +131 000002-3128+0553
Here is the maintenance manual
T2365 80 Maintenance Manual pdf Download PDF
try this first
The hardware alarm you are seeing on the 2265+ indicates the printer is experiencing a "horizontal task error" ie the printer is not able to move the print head or is not able to detect the print head is moving, things you can check to resolve this problem are;
  • Remove the ribbon from the printer, ensure this is not jammed or damaged
  • Power the printer OFF and try manually sliding the print head from side to side, look out for any objects which may obstruct the movement of the print head (pen lids etc!)
  • Ensure the print head gap is not set to close to the paper, thus jamming the print head
  • Remove the paper to ensure the paper is not restricting print head movement.
  • Clean the Optical Timing Strip that runs under the print head, ensure this is not damaged also.
  • Clean the carriage shaft, this should be FREE from any lubricants WD40 etc and dry running. Remove build up of paper dust etc.
If the problem persists it is likely the printer has developed a fault, check the following
  • Worn or damaged timing strip
  • Worn or damaged carriage shaft
  • Fault timing sensor
  • Faulty carriage motor
  • Damaged print head cable
  • Incorrectly connected print head cable
  • Faulty interconnect board
  • Faulty Main Board
  • \More resources here
Tally T2365 hardware alarm 0001 131 000002 2854 2299 Any Ideas
Jun 17, 2018 | Tally Office Equipment & Supplies
Why my printer is not able to cut recipt
Cutter blade may have some receipt paper jamming its movement. It is not a very powerful motor and easily jammed. Open the top and look closely for little cut pieces of paper. Clear out all the pieces and try to blow it out with canned air. Reboot system and check printer settings to make sure cutting function is set. Give it a try.
Mar 15, 2014 | Epson POS TMT88IV Thermal Receipt Printer
In my printer lbp2900b the paper is jammed , as i tried to remove its torn and it was jammed into the roller .now how i will remove it . pl give the solution asap.
If the paper is jammed inside the mechanism, around the rollers (ie, you can see it but you can't pull it) then you need to tear apart the printer. Call up a printer technician or get your screwdriver ready :D
Mar 02, 2011 | Canon LASER SHOT LBP-2900 Printer
I keep getting the message "Out of Paper" or alternatively, "Carriage Jam" The printer is not out of paper - I have removed, straightened, added paper and it's the type I have always used. There is...
It will be good to have the printer mechanism jammed or the paper tracks jammed with paper struck in the roller.
Remove all connections when the mechanism is taken out cleaned and drives checked manually with the motor removed and the drive turned to see that the movements are smooth.
make sure the input sensors are intact , the paper detection sensors.
Sep 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
Epson Stylus Color 740.All indicators flashing (unknown printer error) Have tried troubleshooting advice. ie Turn of printer etc. But this does not correct problem. Any suggestions ?
Sounds like the printer may be jammed. When it goes through it's initialization process, it checks ink cartridge movement, and scanner arm, and when they don't respond correctly, the lights flash to indicate the fault(s).
Try to check for any paper jam first, and work the paper feed rollers slightly to see if they're bound up. Aside from this, it will have to be opened up most likely to see what's going on. I've seen mostly broken gears in the worst cases, but I've also seen paper jams, you just never know till you get in there. If it's under warranty, have it checked out, otherwise what have you got to lose by opening it up and investigating a bit- you might get lucky. If you choose to get it serviced, get an estimate first, since sometimes it's just better to buy a new one on sale, and the free cartridges that come with it are sometimes worth the price of the printer, so it's, basically, free. Good luck, wish I had a simple answer for you.
Mar 27, 2010 | Epson Stylus Color 740 InkJet Printer
Paper jam, but no paper inside
There is a sensor in all printers that report this error. It may be electrical (electric eye) or mechanical (roller connected to a sensitive switch (also electric)).
I am not intimately familiar with the innards of all printers currently in use, including yours. Still, I offer this advice.
Your printer is "jammed" because something is saying so. (What?) The roller and/or switch may be stuck in the 'jammed' position or the electric "eye" may be dirty or possibly there could be a short somewhere (I doubt it, but it is a possibility) Now think about this, the switch is very sensitive, it must be to detect the thickness of one sheet of paper. You will not see a lot of movement if it is mechanical.
Error messages are frequently generated by sensors (switchs of some kind) In your case, the sensor is closed (like turning on a light in the living room) and telling you the light is on in the living room, so to say.
Even though you have inspected the device closely, you must re-examine and find the sensor and clear it.
I hope this information helps you.
There will likely be other question catchers pick up your question and give you other advice. Try all the options you receive until you resolve the error.
Thanks for using FixYa.com
Please vote
positive comments appreciated
thanks
a
Dec 06, 2009 | Lexmark X6675 Pro Colour Wireless...
Carrier is jammed - won't move to left and I don't want to break it - how do I un-jam? it's an HP PSC 2355
A LIKELY problem has to do with the baffle used for the waste ink during cleaning of the jets cycle.
GREAT care is needed to not force and break plastic parts.
Use an inspection/dental mirror and bright light to see what is blocking the movement.
Sometimes an ink cartridge retainer can come loose and jam it.
Nov 28, 2009 | HP PSC 2355 All-In-One InkJet Printer
My printer keeps giving the error "paper jam". I cannot find any kind of paper jam in it. Any ideas to fix this?
these printers will give this error if the main motor drive fails to initiate. its probably cheaper to buy a new printer
Nov 02, 2009 | Lexmark X4650 InkJet Printer
Flashing red button with a triangle and ! in it . printer won't work
If only the attention light is flashing then follow the guide below -
The Attention (amber)
light is blinking.
Attention error. The top
cover is open.
Close the top cover.
printer is out of media.
Load media.
printer has a jam.
1. Clear the jam (see pages 164 through 168).
2. If the location of the jam is not apparent, check
the embedded Web server to find the jam
location.
 If the jam was under the imaging drum, toggle
the registration sensor to check its movement
and replace the registration sensor if it does not
move freely.
 If the jam was in the fuser area, toggle the fuser
exit sensor to check its movement and replace
the fuser exit sensor if it does not move freely.
Jun 07, 2008 | HP Color LaserJet 2550n printer + HP Color...
Samsung SCX 4521F All-In-One Laser Printer Logo
118 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
