Model #40RV52R to a direct sat. receiver
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Direct TV Remote - No Codes Operate TV
I couldn't find any info on that particular model, but if it has a built in DVD or VHS player you cannot program the Direct TV Remote to it. You will have to use both remotes. The Direct TV one to change the channels and the TV remote for the TV functions.
SOURCE: CANNOT PROGRAM dIRECT tv REMOTE
i got the same model tv, and had the same problem..call direct tv and tell them you just got the new polaroid tv...i take it you got it at wallmart......anyway,call them up and tell them you want them to send you a updated remote...since the tv is so new,(came out in october of 08)...your older remote doesnt have the new code for it.
SOURCE: need code to program direct tv for truetech tv
here is a list of all of the direct tv codes. I do not see your TV on the list, which is sometimes the case. Maybe you will find it there. Hope so.
http://2getdtv.com/directv/tv_codes.html
SOURCE: Where do I find the TV codes for a Toshiba 32HL57
try.018.045.128.141.369.379.one of these three digit codes should work.
SOURCE: I purchased a Westinghouse 32"
http://westinghousedigital.com/wordpress/wp-content/uploads/2010/05/Remote-Codes.pdf
That should give you the codes you need. Hope it helps.
