Question about Canon imageRUNNER 400S Copier
Canon xerox i have canon xerox machine in the i get a problem always it is showing a error that no. is E805. pls do need ful in the error. thank you. b_m_w_45@yahoo.com
  • 5,081 Answers
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Posted on Jul 03, 2009
E001
Posted on Aug 17, 2009
Canon 405 error code e805
http://www.copytechnet.com/forums/canon/9744-canon-gp-405-error-e805.html
Quoting:
  1. Canon GP 405 error E805
    E805 (The fan rotation is faulty.)
    If no detail code is indicated,
    suspect the feeder fan (FM1) or the
    reversing guide cooling fan (FM9).
    Is the connection of these fans
    normal? Is the drive signal of the fan
    identified in the previous step about
    22 VDC while the fan is rotating orabout 12 VDC otherwise?
  2. 05-14-2008 #3 songela Senior Tech 100+ Posts
    Join Date Mar 2008 Location dar es salaam
    That is one side with the fans,
    Secondly, if the fans are found right, then for sure you need to change the DC Controller.
    Regards!
  3. 08-02-2013 #4 mehta Junior Member Re: Canon GP 405 error E805
    Originally Posted by logimix
    Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
Apr 29, 2018 | Canon Office Equipment & Supplies
What is a mining of shine E000805-0000 on xerox machin canon ir 2830
I don't have the service manual for this model but on many canon copy machine E805 is a fixing fan error.
Nov 21, 2014 | Office Equipment & Supplies
Error e805 ir 400
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Dec 21, 2013 | Canon imageRUNNER 400S Copier
Canon xerox ir 400 error E805 the problame is machin display open the front door
This problem due to your composite power supply,you can see 3 blue capasitor has burned,change it with 4 amp fuse near that caps
Sep 07, 2011 | Canon imageRUNNER 400S Copier
E805,E803,E002 Error Problem
hi sir my xerox machine ir 400 the error code e0110 so now please help me
Sep 24, 2010 | Canon imageRUNNER 400S Copier
Sir; i have a canon imagerunner6570 model
A E805 is a exhust fan error code. That means that a fan is not working correctly. I believe you may have one of the fans is blocked or a wire is broken. It is either the fan in the cover of the primary charge unit, there is a connector that may have been caught by the fuser unit. It may also, be the sucktion fan in the transfer unit
Aug 02, 2010 | Canon IMAGERUNNER 6570 Copier
ImageRUNNER 400S Copier: what is e805 error & how to clear...
Its a fan related error, basicaly you should check all the fans in copier, clean the filters, reconect the connectors, try to find a bad fan,... When you find the bad fan you can also replace it with new matching PC fan
Pls. rate
May 03, 2010 | Canon Office Equipment & Supplies
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
199 people viewed this question
old marine
old marine
