Question about Nokia 5630 XpressMusic Smartphone
It is one of the worst handset I have ever seen !!!
    President:
  • 1,884 Answers
What is the problem with your phone. It may be the worst, but, you bought it.
Posted on Jul 26, 2009
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
No dial tone but the rest of the phome works
If you have no dial tone (the noise when you pick up the receiver) your line is at fault and you need to contact your supplier. If the calls are coming in and going out but the handset is not ringing, it could be a problem with your main socket. The front plate on new sockets seems to be the part which distributes the calls to handsets. We had this problem. Changed the front plate and it worked. If you've no calls coming in you need a technician and this will cost.
Mar 05, 2014 | Uniden Cordless Phone
NO DISPLAY AND CANNOT MAKE A CALL
Hi, if you put it on the base and after one or two hours there's no charging indication on screen, maybe the battery is faulty or in the worst of cases the handset or base are faulty (electrical power blowout, lighting, etc.).
Oct 03, 2013 | Motorola Mobility L702C DECT 6.0 Telephone
The handset display cannot be seen, the backlighting is working. A580IP handset.
the display unit is not functioning... it is either the problem with the bus(wires) connecting the display and the board, or the problem with the display IC...
backlight is an ordinary led light, it will continue to work whenever there is a power supply to it...
Aug 09, 2010 | Siemens Gigaset A580 IP Cordless Phone
When on handset mode, ear piece does not work, but sound comes out of speakers when on "loud speaker"
maybe its the speaker or earpiece of your mobile i hope....worst if its flex that conects the base board to top board of your mobile.. change it
Nov 26, 2009 | Nokia N95 Cellular Phone
Ge model 28213ee2-a 2nd handset doesnt ring when a call comes in
assuming all the settings are correct, and sometimes there's a tiny switch on the handset for ringer, that has to be on, try the 'page' feature [the button on the base to make the handset ring to find it] - if that doesn't work, there's a very good chance the ringer itself is bad. i've seen that many times.
May 26, 2009 | Uniden Cordless Phone
Receiver rattles. Like something loose inside.
The rattle is probably a weight. On purpose, they put a piece of metal in the handle part of the handset to give it more weight.
If there isn't a secret screw under anything in the handle, it's probably glued or clipped at each end. Those are the worst kind.
Sometimes a slight pressure at the break near the top of the receiver will be enough to seperate it to get a knife in the opening to pry it apart.
When you get the 1/3 part of it up, look to see if there isn't something else holding it. It may lead you to the tab or screw that does.
Before you destroy the handset, look under the receiver part on the inside. With any luck, there will be a part number. You'll need that when you order a new handset :-)
Carl
Mar 22, 2009 | BellSouth Lands Phones
Phone keeps showing out of range
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
Follow the below steps with the handset to solve your problem.
Press and hold the End key down and hold it.
Press and hold the # key down and hold it.
While pressing each of these keys down in order wait until the handset reads deregistration complete is seen.
Then release the keys and place the handset on the main base to register the handset.
Dec 03, 2008 | Lands Phones
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Base won't charge handset
the base of your handset needs to be repair take it to a tech
Apr 04, 2007 | GE 26938GE1 Cordless Phone
Nokia 5630 XpressMusic Smartphone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
