My aircon light is blinking but aircon is not
My aircon only works on fan mode
    Problem Solver:
  • 15 Answers
Your air conditioner's compressor would have gone. Try to change or fill the gas for your airconditioner.
Posted on Jul 03, 2009
  • Roland Chan
    Roland Chan Oct 24, 2011
    maybe your air conditioning have problem because new units if have self diagnostic problem or alarm thru blink
    can i ask you to give the model of your air con.
2 Suggested Answers
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
Its a trane unit model# TUE060A936K3 in cooling mode condensor comes on the indoor fan does not in heating mode every thing comes on but the blower fan does not there is not a led light blinking code...
Either the vent is blocked or the pressure switch that tells it that the purge blower is running is not working right...for some reason that switch is not making contact and so it will not let it light..
heatman101
Aug 11, 2010 | Heating & Cooling
I have a toyota corolla xl 96 model. My problem is that whenever we will use the aircon the engine light will blink and you will see some engine oil spills but if we will not use the aircon the car is...
Are you sure you are seeing engine oil or is it coolant??
Chances are that it is coolant and that when you use the AC the engine is overheating. Do you have a temperature gauge on that car to indicate the engine temperature??.
Make sure your radiator fans are working--when you turn the AC on the fan at the back of the radiator should come on.
Nov 24, 2009 | 1996 Toyota Corolla
My carrier split type non-inverter aircon always blinking
It indicates afault within the unit. Give Carrier a call and get it serviced.
Mat
Jul 01, 2009 | Carrier 36KCARMS Air Conditioner
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Cool/AC light is blinking
Try cleaning the filters & coils good with a shop vac, or a scrub brush.
Jun 03, 2008 | GE Deluxe AGM12AB Air Conditioner
Heating & Cooling Logo
229 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
