Already replaced the 2 yr old fuel lines and that made no difference. The old lines in the tank were not broken, but cracked when I stressed them. I suspect a valve in the fuel pump, but am not sure that would stop it from running once it got started, and it does stop running if I turn it right side up.
How to repair Husqvarna 125. It here https://www.youtube.com/watch?v=XJsv7stNrBc
How to buy the best leaf blower - visit www.leafblowerhq.com for the most complete guidance for buyers of leaf blowers of all kinds. You'll find detailed info on how to choose the best gas powered leaf blower, the best electric leaf blower (corded and cordless) and the best backpack leaf blower
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
SOURCE: repair broken fuel line husqvarna 125b
to replace the fuel line get a piece longer than the old one cut the last 1/2'' down to 1/3 place a stiff wire threw the hole and out the gas cap opening push the line over the hose and slowly pull back till the line pops out then pull the wire out and pull the line threw put the filter back on before pulling the hose all the way threw
sounds like it's going lean lack of fuel check for cracked fuel lines,primer bulb or leaky carb to engine gasket
SOURCE: my 125B leaf blower quit
THEgas cap is bad. Ethanol in gas cause the rubber vent to go bad and not vent gas tank causing a vacume in tank.
the gs cap is bad.
ethANOL
