Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series won't Rinse. Just stops at rinse cycle.
Kenmore 80 Series won't Rinse. My washer just started this, when it gets to the rinse cycle, it just stops. I tried all the settings and the same. If I turn the knob a little to coax it into rinse, it will start filling and then a moment or two later it stops. Play with knob and same result, it starts to fill, then stops. There is no noises and nothing running when it does this. I can hear the lid switch working when I open and close the lid and the lid switch always seems to work id I open and close during wash cycle. I can also wash in the cold setting so it doesn't seem like the cold water valve. Any ideas?
  • tempinyuma Jul 03, 2009
    Is this something that I need to get a service call for or something I can do? How much shuld it cost? Is there any way to reset it, perhaps by unplugging it? This is not a digital washer but the standard knob style, I know that everything seems to have a computer in it any more but his too?
  • 749 Answers
Hi it seems like your dishwasher's programming system is malfunctioning, you will need to get it 'reprogrammed' so it will function correctly and complete its cycles.
Posted on Jul 03, 2009
  • Muzzammil Ishfaq
    Muzzammil Ishfaq Jul 03, 2009
    it may have a auto reset system, you can try this by just unplugging it for ~30mins and try again, you will not be able to reprogramme it yourself as you will need specialized equipment, it will not cost too much as it only needs reprogramming and nothing needs replacing.
Rinse cycle doesn't work
Your cold water valve is clogged. Most likely needs to be replaced or at least cleaned.
www.oc-repair.com
Feb 09, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
147 people viewed this question
Sal De
fordexpert
Robert Rankin
