Question about LG Televison & Video
The tv screen has gone fuzzy and the remote control won't work. Every time i press a button on control STB lights up. I have tried changing the batteries but no luck? Was trying to sort the fuzzy screen out (think one of my children pressed a button on remote) when all of a sudden control stopped working and every time i press something STB lights up. Now i cant fix the fuzzy screen because control wont work.
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
likha
  • 790 Answers
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Posted on Oct 09, 2007
wyoed1
  • 211 Answers
SOURCE: Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Posted on Aug 19, 2008
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
My new amino remote only works on my tv and not on my aminorouter. If a switch from tv to stb I can still use the vol button but the ch. button does not work. I cant change the channels on the amino...
Try re-coding the remote. Hold down STB and OK for a few seconds. Then when the red light is steady on the STB button you put in the code 000. By doing this you have reset the remote control. Also a good trick is to remove the batteries and put them back in. With that you are basically turning the remote off and on again. The good old restart.
Mar 22, 2010 | Philips PM3S Remote Control
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
Dec 07, 2009 | Televison & Video
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Jul 19, 2009 | Televison & Video
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Remote stuck on STB
Take the batteries out of your remote and let it sit for a few minutes. In plug your TV also. Wait a few minutes....Make sure the selector buttons are not stuck on the remote. plug things back together and see if it operates normally.
Feb 02, 2018 | Televison & Video
Televison & Video Logo
113 people viewed this question
