It doesn't seem that the spray is reaching the to shelf
SOURCE: Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
SOURCE: I have a GE dishwasher; spray arm at the bottom does not rotate.
make sure that there is nothing blocking the racks, no big pots or pans, if thats ok then take out the bottom rack, u will see the sprayer, use something long, a screwdriver should do, u should see a slot in the sprayer at the bottom, stick the driver through it and give it a turn, it will loosen, take it off and make sure it isnt clogged, also, ull see a little cover that looks like a grate, take that off also and make sure it isnt clogged under neath
SOURCE: top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
SOURCE: My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
4w56er
