Question about Hotpoint HSS25GFP Side by Side Refrigerator
Noise My refridgerator is 2 years old, there is a whining noise and surging noice comming from the freezer side. I unplug it and it helps for a little while then it starts back up. The noise is driving me crazy, any ideas.
  • 3 more comments
  • Anonymous Nov 10, 2007
    Hi have the same problem with my hotpoint rfa60. any suggestions greatly appreciated
  • Ronald1 Nov 29, 2007
    How can the board cause the fan to be noisy, is it not sending enough electricity to the motor. Thanks
  • Ronald1 Dec 17, 2007
    supertechks, what is the other name for this item so I can get one ordered. I search mother board and all I come up with is for computers. Thanks
  • n_pakvasa Sep 25, 2008
    We have GE model # GTH #22s BNARBS stainless steel single side refrigertor. Makes terrible noise for the past few days. Any ideas?
  • blgardner Nov 23, 2008
    Annoying whirring/humming sound from the evaporator fan recently started on my $7000 built in GE side-by-side refrigerator and it's driving me crazy. All internet signs point to some sort of mother board issue that's causing the fan to spin at a speed that leads to this annoyinhg pitched sound. GE is coming out this week but am fearfult that I am going to hear the "operating as designed" arguement. Is this a known issue by GE? Any official docs that I can point them to to ensure it gets fixed? the noise is driving me crazy.
Well, my GE side by side does the same thing...I actually changed the evaporator fan motor and it made the noise about a week after I changed it, then it quit for about 6 months, then started doing it again...I actually just looked this up because as I type its doing it...There is one simple solution to this problem...Dont buy GE products anymore...I think they are garbage...I am not going to change the fan every six months for $75 dollars just because GE makes cheap ****.
Posted on Mar 27, 2008
  • jeka28 Mar 27, 2008
    The evaporator fan is located behind the shroud that is behind the ice maker...You have to remove the ice maker, then remove the shroud, and it is behind that...It wont matter though...Like I said, I put a brand new fan in and its only a matter of time before it starts doing it again.
Where about is the evaparator fan located
Posted on Dec 29, 2007
  • 42 Answers
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Posted on Nov 24, 2007
  • Keith Smith Dec 14, 2007
    I'm sorry Ronald1,
    I did not check till now. The GE mother board is a very strange board. It has been to me and many other technicians very baffling due to the many strange things it has been known to cause. Anything from strange evaporator fan motor (freezer fan motor) noises to erratic dispenser functions as well as interior light abnormal operations.
    It may be that the motor is given the proper DC voltage then an improper AC voltage or for some other reason but normally that is the cause of the strange and annoying freezer fan motor noise.
    If you get this and find I am correct please come back and rate me as a FixIt.
    supertechks 12/13
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Whining sound from motor on Frigidaire upright freezer
Hi: It sounds like you bought a frost free freezer as it has a fan. The fan will come on to circulate the air. It will not necessarly run continuosly. The noise is most likely coming from the fan. I sold Frigidaire freezers for years and they are noisy compared to a refridgerator. If you think it is louder than it was when you bought it, I would replace the circulating fan. Also look at the back wall for frost as it could be a bad defrost heater blocking it with ice. Most likely just the fan though. Since it's in a detached garage,and you won't have to put up with the noise inside your house, it could run a while before failing. The fact it's getting cold is a very good sign.Also as you asked 2'nd, a freezer is ok in an unheated garage. Don't put a refrigerator in there. Unless It is a Whirlpoll Gladiator that is designed for such applications. Use to find out where the fan is if you feel it is necessary to replace it. Its not a tough job if you are handy. Their shipping is expensive so you might want to buy it locally.
Jun 22, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
May 28, 2009 | Refrigerators
Whineing noise\and leak on freezer side in the bottom of it
yes the water in the bottom is because your drain tubing is cloge thid is the small hole in the frezer area defrost your fridge use a wire to clear out the debri that clogs your tubing the water should drain in the pan where the compressor is thanks from gilles
Feb 10, 2009 | GE GSS20IEP Side by Side Refrigerator
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Noise in my refrigerator
Replace the evaporator fan motor that will solve the problem
Nov 29, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
574 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
