Enigma Air Conditioner showing L1 error code
I have the same problem as another one on this site. My enigma air conditioning unit shows an error code L1. Tried everything from cleaning to completly powering down but it always come back up with L1 when re-started.
5 Suggested Answers
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
SOURCE: i desperately need a new
I bought a mini remote on the net, learns just by pointing at the unit. Cost about $25, from China or Hong Kong. Works perfectly.
Cheers
Col
Posted on Dec 08, 2010
Hi, I have an enigma air conditioner that has the timer light continually on and the run light flashes at 5 second intervals (machine is not running) any clues?
get the program right and turn off the timer
it is not really necessary if you set the temp setting at 25 c to start with
Jun 25, 2017 | Heating & Cooling
My enigma 8 autoclave is showing an error code of E21 and this does not appear n my user manual...help
This really comes under the category of laboratory equipment, not digital cameras, I'm afraid.
Aug 10, 2016 | Cameras
Enigma SLR61-GW. System runs for about 30 mins and then shuts down and a status light blinks 4 times.
Open the front end of the blower.
You will find tow filters that slide out.
Clean them with water and replays them.
Go to the outside one, take a hosepipe and run a strong stream of water thru the radiator until its clean.
This will solve your problem.
Good luck.
Oct 23, 2015 | Heating & Cooling
Why is e5 showing on my 15000 frigdare window unit
Ive seen ES, in two sites http://www.doityourself.com/forum/air-conditioning-cooling-systems/532071-frigidaire-ac-window-unit.html
http://www.searspartsdirect.com/window-air-conditioner-repair/error-codes/frigidaire-window-air-conditioner-error-codes.html So I'd tend to agree with the majority.
Mar 14, 2015 | Heating & Cooling
Air conditioner keeps turning off
Never heard of that brand. These appliances are designed to shut down and protect themselves when there are certain problems. High head (discharge) pressure (dirty or obstructed condenser coils) or low refrigerant (Freon) charge (leak anywhere in the sealed system) will cause the unit to shut down. Look to make sure that the unit's discharge is clear (not obstructed), and that the warm (condenser) coil is clean.
Dec 01, 2013 | Heating & Cooling
An error E-1 shows up and won't reset
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 23, 2011 | Casio Office Equipment & Supplies
My unit show a code error E1 the model is lp0910wnryo
heatman101
Jul 07, 2011 | Heating & Cooling
My unit show a error code E1
heatman101
Jul 07, 2011 | LG LP0910WNR Air Conditioner
I desperately need a new remote for my enigma SLR 61D air conditioner pls help!!!!!!!!!!!!!!!
Cheers
Col
Nov 19, 2010 | Heating & Cooling
Heating & Cooling Logo
412 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
