Question about Gateway 19" Flat Panel LCD Monitor
Power not being received by monitor
My 19 inch Gateway flat screen is not receiving power. I tried 3 different power cords and connected it to 4 different power outlets ,all working fine.
Does anyone have a solution for this?
  • 51 Answers
RMA it if its under warranty. Throw it away if its not.
Posted on Nov 10, 2007
Gateway 19 inch fpd1976w problem
Power supply will be the first place to look, look for bad caps (bulging tops or bottom seals). Check it out and post back what you find so we can guide you further, see example of failed monitors due tobad caps:
The high pitch you are hearing can be from the bad lamp soldering connection, it is arcing.
Jan 24, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
No sign of power
have the switching power supply checked or might need a replacement
Aug 10, 2009 | Gateway 19" Flat Panel LCD Monitor
Playstation not receiving power
This could be a problem with your AC power cord, try these fixes. If they do not work you ca contact sony at:
  • The console might not be turned on. Turn on the console using the main power switch on the back of the console.
  • Make sure the AC power cord is securely connected.
  • Visually inspect the AC power cord for damage. Do not use if frayed, cut, or damaged in any way.
  • Confirm the wall power outlet is active (receiving power). Try a different power outlet.
  • If possible, test the power cord by connecting it to a different PLAYSTATION 3.
  • If possible, try another AC power cord on your PLAYSTATION 3.
  • If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PLAYSTATION 3 power supply and the PLAYSTATION 3 may need service.
  • Make sure the vents are not obstructed in anyway.
  • Make sure there is adequate ventilation for the PLAYSTATION 3. There should be at least four (4) inches of clearance between the air vents on the system and any walls, televisions, entertainment centers, etc. Otherwise the unit may not function properly due to what are actually environmental issues.
  • Jun 23, 2009 | Sony Playstation 3 (PS3) Console
    Gateway 19inch wide screen, lcd monitor stopped working randomly.
    It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
    May 06, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
    Buy a power cord for Gateway 900?
    I recently purchased a power cord on ebay. The price was awesome. Everywhere I went wanted over $100 I found mine on ebay for $12. So try ebay.
    Jan 04, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
    Mag Innovision LT982s 19 inch flat screen monitor
    Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
    Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
    Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
    Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
    Gateway 19 in flat monitor Model 900G
    Does the power button light up or blink at all ?
    It probably is the power board/ inverter. I fix many of these.
    To TeeKO, did you try moving it back to see if it was maybe a bad household receptical ?
    Jul 29, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
    Power supply for Gateway FPD1975W 19 inch LCD
    try replacing the crystal on the power supply 8 out of 10 times it is the problem
    Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
    19 "lcd gateway monitor will not power on.
    Have you tried your monitor on somebody else computer?
    Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
    Gateway 19" Flat Panel LCD Monitor Logo
    91 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
