Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My hotpoint aquarius wma56 washing machine wont fast spin
My washing machine will not fast spin on any cycle is it the brushes
  • 3,741 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Oct 05, 2009
Hotpoint aquarius 1300 wma56 not draining. I've taken out the filter and cleaned. Put all back together, did spin cycle - all good. ran a full wash. Now stuck with water in not draining or spinning.
The motor is not reversing direction when it is supposed to pump out the water from the machine. The timer may be the problem or the motor itself.
Apr 26, 2016 | Hotpoint Washing Machines
Wont spin and the front indicator lights are going from pre wash to end in a night rider fashion
try checking ur door switch may also want to check the water pressure switch which signals the machine to go into wash after the fill cycle
Feb 11, 2015 | Hotpoint Aquarius WMA56 Front Load Washer
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Washing machine wont fast spin
Because I don't have your model number or brand I will let you know that this could be a series of things that could cause the problem. If your washer has a lock for the door and at the time of spin you smell plastic melting in the air then I believe this could be the problem. If your washer has an electrical smell of burning od the motor then the motor could have a bad run capacitor or defective windings. What ever the case you need to stop using the washer until the problem is resolved. Please tell me more about the problems and get me the model and make, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://sites.google.com/site/sublimeappliancerepair/Home Check out SublimemasterJWebster He will get you going. Thanks, please rate me , Sea Breeze
Jul 03, 2009 | Washing Machines
Machine takes in water then wont go any further
Main motor needed new brushes, all working well now.
Jan 16, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
539 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
