Question about Bosch Dishwashers
Model probably 039-119 or WKZ solo model or GV630 S/U no official model plate. about 8 years old. bought with a service top. we want to remove the service top.
  • noeljan Jul 03, 2009
    we replacing the tiles on the kitchen floor by going over the exsistinf slate floor.
    the dishwasher is just 4 cm. too high.
    we therefore have to take the plastis service top off to find space under the custom made bench.
    the installation instruction is not slear how to install or remove the service top.
    Genius:
  • 1,689 Answers
Hi noel,
the part and how to remove the part you are targeting is shown on the link below as with other Bosch dishwashers.
http://www.repairclinic.com/Dishwasher-Repair-Help
http://www.devicemanuals.com/guide/Dishwasher/Bosch-manuals.html
http://kitchen.manualsonline.com/manuals/mfg/bosch/bosch_dishwasher_product_list.html
http://www.repairclinic.com/Bosch-Dishwasher-Parts
hope this helps,
regards,
voodoo
Posted on Jul 03, 2009
  • 749 Answers
What exacly do you mean by the service top? also the model is wrong pls find the right one thanks
The screen is blank. I left the washer unpluged for 5 minutes and the screen is still blank. Any advice? Thanks...
Without model or manufacturer, little can be done to answer question. Usually there is a name plate on the back of the machine. Call a washer repair service is another altenrative
Dec 05, 2014 | Washing Machines
Model w10311121b no power
Hi Scott. It appears you have the same dishwasher as mine bought in 2010- it worked sporadically for several years. I bought one year warranty ($289) in Feb2014 . Over 2 months, service technicians replaced 3 parts (user control board, motor control board and water sensor) hoping that each would fix it. They told me to run hot water before starting a wash cycle. Dish washing cycle failures were still sporadic and it finally lost all power in May2014. Service techs would not come out so I confirmed house power supply with a multimeter and then took the door apart to access the latch. I determined the latch kill circuit was not assembled properly and it had carbon buildup which I scraped off.
If your warranty has ended and you attempt this, do not use a power screw driver with these Torx screws as you can easily strip the threads or damage the plastic user control housing by screwing in too far on the top screws. (especially if you forget to reinstall the internal handle which acts as a spacer).
To disassemble: Remove the top 4 screws and top side screws, loosen the middle and lower side screws as needed. Separate the washer door face wide enough to remove the user control board, let it hang by the cord. The handle will be loose in the way, remove it. The latch has a white plastic kill circuit which is held to the latch with tabs. Unplug the circuit and carefully remove it. The circuit comprises 2 flat metal sheets that are pushed together by the latch lever when the door is shut. These plates separate when the door is open to kill washer power. The latch lever should be under both circuit plates with the shorter plate on the bottom. (long plate, short plate, lever, white housing). Reassemble, remember to include the handle My dishwasher operates properly now.
Apr 19, 2014 | KitchenAid Dishwashers
Where is the IMRC (INTAKE MANIFUL RUNNER CONTROL) on a 2001 Ford Mustang.. Got code P1518.. Had a fuel injection cleaner done, but service engine light is still on.. So Want to check it out. Thanks
Hello, First the Service light has to be cleared from the computer by a scanner or by disconnecting the NEG battery cable for 10 minutes. The scanner is a better idea because some radios and antithefts can act up when the NEG connection is open.
If you still have a problem and have the 3.8L V-6 engine for the 2001 year model this engine did not use a manifold runner in a conventional way. The code means on your model, that a plastic part on a runner actuator probably broke and the rod underneath is loose. There is also a repair program for your DPFE which carries a Ford Repair Program number 02m01 and its free. Ask for an OASIS test at a Dealer.
The V-8 models and in later years used a dual channel intake for each cylinder. One part is a constant velocity port and the other channel opens up above 3000RPM. If you have a V-8, get new gaskets, choke cleaner and remove the Intake to clean the runner plates. The plates can stick if they are dirty.
I hope you find my solution very helpful.
Apr 03, 2011 | 2001 Ford Mustang
Miele G880 dishwasher, stuck in "Top Solo" mode.
If the unit is really stuck in 'top solo' then the most likely culprit is the top solo solenoid valve located off to the side of the circulation pump. It's most likely jammed in the engaged position. You will have to uninstall the dishwasher, lay it on its left side and remove the bottom panel to access it.
Feb 13, 2010 | Miele G880 Dishwasher
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
Solo 9100 battery
Well, 8 years is an excellent life for any laptop battery. Being that old it will either be a nicad or nimh battery, both of which suffer from battery memory. There is very little you can do. Sometimes, charging the battery as much as possible, REMOVE IT FROM THE LAPTOP, put it into a plastic bag, seal it against moisture, and then put it into a freezer for 12 hours. Replace it into the laptop, charge it again, repeat twice more. If the battery has a bit of life in it you may be able to reclain SOME of it's capacity back. This is a last ditch effort, and should be carried out as a last option. That leaves either buying a new battery, this eBay link will take you to one
http://cgi.ebay.co.uk/NEW-Laptop-Battery-for-Gateway-Solo-2300-2500-9100-9150_W0QQitemZ230370600615QQcmdZViewItemQQptZLaptop_Batteries?hash=item35a32866a7
It's probably time to replace the whole laptop though.
Hope this helps
Jan 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
Make, Model, & Year of Clark Forklift
Contact a Clark Dealer or service center. They can trace the chassis numbers. Don't run it without a plate on it, it's illegal and totally uninsurable.
Oct 08, 2009 | Electrical Supplies
Escort doesn't work
There is no place where you can send it in for any type of service. Not only that, your Solo's performance is horribly outdated compared to any current Bel or Escort radar detector model. Even Whistler offers high end models which significantly outperform your old Solo. It is time to upgrade, plain and simple.
Dec 18, 2008 | Solo S2 Radar Detector
What is the wattage on my old microwave
Based on its age and description it is probably 600 watts.
Nov 24, 2008 | Kenmore Microwave Ovens
Dishwashers Logo
263 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
