Question about Asrock P4VM8 Motherboard
Not able to complete windows xp setup
Post and locating drives takes about 2 mins to run. can't set the correct date in bios. won't complete windows setup, stop: 0x000000d1....or 0x0000000a....driver_irql_not....fault
I found a site about this particular error http://0x0000000a.com, I had a problem with XP setup as well, now resolved. Check it, it has much information on XP issues. Try them all until you find the one that helps.
Posted on Aug 31, 2009
    Scholar:
  • 111 Answers
First let's try to "flash" the BIOS to correct the erroneous data crashes. Here's the link for the motherboard:
http://www.asrock.com/mb/overview.asp?Model=P4VM8
After flashing go back to the BIOS and setup the appropriate settings, after that reboot and try to load Windows. If this fails then possibly you may have faulty memory modules or they are not seated correctly in the motherboard, try swapping them, hopefully they are the same. I hope this helps.
Posted on Jul 03, 2009
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
How to install windows xp
To install Windows XP :
Required items
1: Windows XP CD ( SP 1/2/3 )/ Windows XP setup in a USB drive ( please ensure that you have made the USB bootable or it won't be detected )
2: CD Rom Drive ( if you want to install by CD )
3: USB Drive ( if you want to install by USB )
For a fresh install , follow the following steps accordingly :
1: Insert the CD into the Drive and restart the PC.
2: Note that your boot settings in the bios settings are correct (i.e 1st Boot priority CD drive if you are installing with CD and 1st boot priority USB if you are installing with Pendrive ).
3: Follow the steps shown on the screen which will throw a couple of options and settings.
4: Click on ' Install a fresh copy of Windows ' when asked for.
5: Select the drive in which you want to install it , it will be formatted and new windows installation would take place in that same drive.
6: Set your date and time region , enter the serial key when asked for.
7: The whole process should take around 45 minutes.
You are done installing it..Congrats!
Kindly note that installing any version of Windows by USB is always quicker than installing by CD/DVD.
If you want to ask any other question , I am here.................
Oct 28, 2013 | Acer TravelMate 650, 660, 800, 6000, 8000,...
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
How to install xp
  1. Place the Windows XP installation disk in your Compaq Presario notebook's CD or DVD drive, and restart the computer. Press any key on your keyboard when prompted.
  2. Press the "Enter" button on your keyboard when you are brought to the "Welcome to Setup" window. Read the XP license terms and tap the "F8" key to verify that you have read and agree to them.
  3. Select the hard disk drive on which you wish to install the Windows XP operating system. Use the arrow keys on your keyboard to toggle between options.
  4. Press the "Enter" key after highlighting the location where you would like to install XP. Windows XP will begin copying installation files to your computer. XP will restart your computer automatically upon finishing.
  5. Select the region you reside in and your primary language in the window that appears after your computer restarts. Type in your name and the organization your computer is affiliated with (if any).
  6. Enter the 25-character product key that was included with the Windows XP installation CD. Click the "Next" button to continue. Type in a name for the computer and a password for the administrative account.
  7. Choose your time, time zone, and the correct date in the following window, and click "Next" to continue. Select "Typical settings" on the "Network Settings" screen and hit the "Next" button.
  8. Enter a workgroup name if your Compaq Presario CQ50 notebook PC is a part of a connected network of computers (such as at an office), and click "Next" to proceed. Windows will restart and bring you to a "Welcome" screen, completing the installation of XP on your Compaq Presario CQ50 notebook PC.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 12, 2010 | Compaq Presario Notebook
Time/date never stay set.f1 f2 f3 always there on start up
This sounds like the cmos battery is low.
This battery sits on your motherboard and provides the ROM with energy. Replace this small battery, set date and time a final time and then it won´t happen again.
May 28, 2009 | Computers & Internet
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
Bios problem
change the cmos battery. and then get an antivirus scanner like kaspersky and then download combofix and run it
Nov 28, 2008 | Microsoft Windows XP Professional With...
Want to erase drive
If your Laptop is purchased with Recovery Disk, you can use that disk to restore the default setting of your laptop. It usually FORMAT your hardisk and erase all programs and files saved on your Hardisk. If Recovery Disk is not available then you can simply use your provided Windows Installer to format your Laptop and install a Fresh Windows on your Laptop, be sure to format the Whole Disk Drive to erase the files.
Jun 11, 2008 | Dell Inspiron™ E1505 PC Notebook
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Asrock P4VM8 Motherboard Logo
169 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
