Question about Sony Cyber-shot DSC-W55 Digital Camera
My camera will just not turn on.
It won't turn on whatsoever. I've tried charging the batteries, taking them in and out, cleaning my camera and pressing various buttons to see if it will just turn on, and no luck.
My camera is screwed aint it? :/
I need to upload pictures but they're all in a memory stick, is there anyway to upload them without the camera?
Many thanks,
Sam.
  • 126 Answers
Buy a memory card reader. It is a small box that connects to the USB port of your camera. Once your card is inserted your computer will install the drivers and come up with options as how to view or download the images.
Posted on Jul 03, 2009
Won turn fully charged battery
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Nov 24, 2017 | Sony Cyber-Shot DSC-WX9 Digital Camera
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
I accidentally dropped my samsung S1070 while I was taking a photo, and the lens is now stuck out. It won't turn on, and we've tried replacing the batteries and taking them out. I've also tried...
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Sep 04, 2011 | Samsung S1070 Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nov 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
101 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
