Question about Krups Small Appliances Espresso Machine
Breville Aroma Style wont turn on
I have a Breville Aromna Style machine. I plug it in and turn the power on and press the power button. The light goes on then straight off again. Sometime there is a faint click in the background.The clock and other buttons don't work.
    Sergeant:
    Champion:
  • 245 Answers
Looks ur on and off switch is faulty......bring the machine back where u got it from and if under warren tie ask for a new one
not sure how long u got this machine....
Posted on Jul 03, 2009
Turns off after heating up once the coffee button has been pressed
Most likely faulty power supply very similar problem to no steam
Be very careful as the powersupply is directly connected to the mains
You can get a replacement capacitor 1.5uf 275VAC from radio Spares online
http://australia.rs-online.com/web/p/polyester-film-capacitors/0148496/
  1. I've had same problem twice
    Once Breville fixed under duress as just out of warranty and no parts
    Last week same problem.
    I tracked problem down to the big yellow 1.5uf 280v capacitor on the power supply board.
    It wasn't passing enough current
    when plugged in the 24volts and 5 volts were OK
    when pressing the On button the Heater relay calls and on light flashes the 24 volt drops to 11volts and the 5v to 4v
  2. Once up to heat the 24 voltage rises to 14v
    when you press the steam button there the 14vis no enough to call the heater relay and the seam light just keeps flashing.
    I replaced the faulty capacitor and all good coffee and steam
Jul 04, 2013 | Breville BES400 Espresso Machine
When i turn on, the green light comes on then goes out,why
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 28, 2012 | Computers & Internet
I have a Breville Fresca BES860 2Cup Coffee Maker and I've lost my manual. The Clean light is on and I can't remember what to press to start the clean process on my machine. Can you please...
Turn your machine off, then push and hold the 1 and 2 cup buttons and then while still holding them push and hold the power button. Wait until the clean cycle begins.
Sep 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
H owdo you clean the machine using the tablet ? Thanks
  1. Turn machine off.
  2. remove group head (portafilter)
  3. place single or dual cup filter in group head.
  4. place rubber bung in group head.
  5. place one tablet in space in bung.
  6. replace group head in machine.
  7. This is where the instructions lead you astray.
  8. DO NOT PRESS 1 & 2 CUP BUTTONS SIMULTANEOUSLY WITH POWER BUTTON.
  9. Press & hold 1 & 2 cup buttons simultaneously, on their own.
  10. Now press the power button while still holding the 1 & 2 cup buttons.
  11. Cleaning cycle will start, and will take around 5 mins to complete. Book says it will beep 3 times when finished haven't heard this yet. Just wait a couple of minutes extra and all should be well.
  12. Clean me light should be out and tablet disolved if not repeat steps again until tablet disolves.
Dec 08, 2010 | Breville Fresca BES860 2Cup Coffee Maker
Steam function on the BES400 just stopped working! its been working fine for about 10 months & now the light just continues to blink, no pressure, no steam!
I have the same problem. Mine is 2 yrs old. Boiler is OK, just no steam. I opened it up and the controller board has a blown elecolytic cap. However, after replacing this still no steam. I would guess it needs a new controller board. I will try Breville...
Dec 07, 2010 | Breville BES400 Espresso Machine
The steam light on my Saeco Aroma does not turn on (and no steam comes out), even after the brew light turns on and I press the steam button. How can I get my steam to work?
HI
It is probably your steam thermostat that needs to be replaced. There are 2 thermostats. The Brew and steam. If one of them fail it won't heat the boiler for that mode. They are easy to replace.
Oct 05, 2010 | Saeco Aroma Espresso Machine
Coffee maker doesn't heat when turned on
We are having the same problem. Any answers?
Feb 17, 2010 | Krups FME4 Coffee Maker
No steam on saeco aroma redesign
Hi
That is probably you steam thermostat. Its a 127c thermostat.
Oct 27, 2009 | Saeco Aroma Espresso Machine
Krups Small Appliances Espresso Machine Logo
162 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
