Question about Labtec C-322 Headset
I cant talk
I was playing Day of Defeat and tried to talk into the mic, and no one heard me. And when i open my mixer, the microphone icon is gray. Is there anything special i have to do to fix this problem?
  • koes Feb 19, 2009
    hearing is fine - others cannot hear me.
  • 156 Answers
-> make sure mic is connected correctly in the correct slot to the CPU
->go to control panel-> sound and audio and there is seperate tab for "microphone"-> have th volume to be full
-> you can test whether the mic works there itself.
Posted on Apr 12, 2008
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
Everytime i get onto skype the person i call cant hear me but i can hear them. The video is fine.
Plug your mic in to the mic socket on the computer & switch it on, go to the speaker icon down near your clock(bottom right) right click on it & open the mixer turn the fader up on the mic or select the mic as your default record device,if you need more help then i will need to know what operating system your using i.e windows XP / VISTA / 7 etc.....
or find the sound & vidio setup option in skype.
Nov 02, 2010 | Toshiba (P000257700) Microphone
I just bought a new gigaware earclip monoheadset with mic. the problum is i cant seem to get the mic working the sound works great but i just cant get that voice to work
Hello Mithmar hi, try setting the volume for your microphone, (i'm assuming you are using X P) to do this right click the speaker icon (or the mixer icon) on the lower right side of your screen, you will go to the volume controls section, goto options, then properties, select recording. check the microphone, then click apply/ok. On the mixer there is now the microphone slider. Test your microphone by loading the sound recorder program (start, all programs, accessories, entertainment, sound recorder, press the red button) then shout to the microphone, you should see wave patterns on the recorder, your microphone is working fine. at this point let me know your progress.
Oct 09, 2010 | Audio Players & Recorders
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
People can hear background noises on my PC but not my voice
Perform some simple steps as follows.
1. Double click on the volume control icon in the system tray, that is on the right hand bottom side of the screen. Check if the microphone is muted.
2. Right click on the same icon, and select "adjust audio properties." You will now get a window that says Sounds and Audio Devices Properties. Click on the tab named voice on top of that window, and check what is selected as the voice recording device. Check in the drop down menu to change the device and use the "test hardware" option to test the mic.
3. Make sure your microphone is working fine. Other people are not hearing your music from your microphone, but from your system itself.
Get back if you have additional questions.
Jun 15, 2009 | Logitech 250 Headset
Cant get any sound from mic!!!!
Go into Play control on your computer. Click on options then properties. Look at your settings for playback and recording. Check play control and your source eg. microphone. To reach this double click on the speaker icon in your toolbar or you can find it under sounds and devices in your control panel.
May 23, 2009 | Samson C01U Consumer Microphone
I cant seem to get my microphone to work I have a store bought mic that I have hooked up to a 1/4 to 1/8 reducer plugged into my 1/8 mic port and it wont seem to work
A simple mistake that I have made in the past is that the mic is turned off. Is there a switch on the mic, and if so, make sure it's on. :)
After that, check in your mixer (Usually a speaker icon in your system tray) and make sure the mic isn't muted, and the volume is up. Also, if you have a mic boost, enable it. Try screaming at the mic, sometimes it's working, but really quiet.
Jun 20, 2008 | Computers & Internet
MIC
Does she have a microphone plugged in? I dont think the 6400 has a built in mic.
If you're sure your mic works then open the sound mixer (click the speaker icon by the time in the lower right) and click "options" then "properties" and select recording. Click ok. Make sure "microphone" is selected.
Hope this helps!
Dec 25, 2007 | Dell Inspiron 6400 Notebook
Microphone Line Jack Trouble
it sounds like theres a switch on your mixer to lower the music when the mics switched on, called talkover.when you switch the mic off the music will return to normal levels. find the switch on the mixer and set it to 'on' not talk
Dec 04, 2006 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
Labtec C-322 Headset Logo
154 people viewed this question
Top Labtec Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
aravind shet
aravind shet
Are you a Labtec Radio Communication Expert? Answer questions, earn points and help others
