Solar 125 Amp Analog Battery Load Tester Logo
j
jason s rhodes Posted on Sep 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is a load tester for a batterie
When i put a light tester on both battieres the light goes on but i have no power what does a load tester look like and can i charge them with my car to rule out it being the charger. my grand parents left it charging 24-7 i know thats not good
  • jason s rhodes
    jason s rhodes Sep 14, 2014
    also its a weel chair pronto m 51
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,001 Answers
  • Posted on Jan 04, 2017
wwlvictoria
Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603915
Points
6027
  • * Highly Durable: The canvas is created to withstand rugged durability for outdoor use. Exposure to damp conditions will not damage the exterior part of the solar charger.
  • * Chornic solar charger is designed to the highest technical specifications and standards ,It will supply years of maintenance free use.
  • * User's Manual,14 watts foldable USB Port solar charger.
Chornic 14W Foldable Solar Charger with 2 Port USB Charger Build with High...
jabberwoky
Level 3:
  • Master 739 Answers
  • Posted on Sep 14, 2014
jabberwoky
Master
Level 3:
Answers
739
Questions
0
Helped
229846
Points
3082
A load tester is typically a resistance pack with an amp gauge to see how the battery deals with current draw. most automotive parts stores have one to bench test car/motorcycle batteries, which they do at no charge (pardon the pun).
Batteries can have a "surface charge"(voltage) which will supply low current at the specified voltage from a battery with bad cells, but when a real operating load, such as for an electric motor, the charge drops to zip..
If the charger is putting out voltage to the battery while it's plugged in then it would definitely be a battery issue, generally the charging system for electric wheel-chairs has regulatory circuits to prevent over charging so having one plugged in when not in use typically doesn't cause issues.
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Charge the battery on my terminator scooter it shows full but soon as I get on it it loses all the power
hi get youre batteries load tested your battery lights r not a true reading on battery condition if u put 2 batteries in that r showing weak on the load tester u will still get a good reading .....hope this helps.......
2answers
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
1helpful
2000 toyota celica gts i have a constent draw on the battier how do i check where its coming from?
put a test light between the negative battery cable and the battery remove fuses one at a time until the light goes dim that will tell you what system has the draw also unplug the alternator that can draw as well
2helpful
2answers
How do know if remote control is not working after putting in new battiers
The remote can be tested with a tester--the most common kind is a laminated card with a strip that illuminates when the remote is pointed at it and buttons pressed.
Many digital cameras in a dim or dark room will react on the display screen in the same way--the card type tester is not expensive and requires no batteries.
If you get it tested and find NO functions I can provide advice.
If some buttons work but others do not I can help.
If the remote checks good then the set may have an issue with the receiver (tiny) in the front of the set that receives the signal from the remote and processes it.
SD TECH
1helpful
My battery wont keep its charge or charge properly ive tested the
Go to an auto parts store and buy a load tester for the battery. It doesn't cost much and sometimes if you bring the battery there they will test it for you with a load tester. It may have a dead cell which won't allow it to hold a charge or put out enough power. If you need a battery, some shops will install them for free. Good luck.
2000 Ford Excursion has developed a problem of not turning.
Yes replace the battery and I dont care what the battery tester says. The grid in the battery is cracked and when battery gets hot it opens up creating an open circut. You may have enough power to run your accesories and lights but when you try to pull a large amperage draw it just wont send enough current to the starter motor. After the battery cools for 2 or 3 hours it works fine. This is a common failure on most modern batterys today. Electronic testers can be fooled by this problem. The only tester that will find it is a carbon pyle load tester that will put up to a real 500amp load on the battery. I see this problem 3 or 4 times a week.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Battary light would not go off
Have the battery and the alternator tested under a heavy electrical load. Some of the cheap battery testers will not indicate a bad or weak cell. Also your alternator may not put out enough amperage to keep up with the electrical demands placed upon it. A good battery tester is a carbon pyle tester. Good luck.
Top Solar Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Solar Measuring Tool and Sensor Expert? Answer questions, earn points and help others
