Question about RCA D52W19 52" Rear Projection Television
How to remove black wire and where can I purchase new wires?
I want to know how to remove the black wire from flyback.
5 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Flyback install
IT twisted off turn clock wise and wirer should come out red is easyer to remove,1 goes to high voltage tripper red black goes to focus&screen drive controls.
Posted on Sep 15, 2008
ladywinn
  • 5138 Answers
SOURCE: How to remove wires from flyback 259296
they are suppose to twist out.
Posted on Sep 24, 2008
SOURCE: I am replacing the flyback transformer
The wires don't come off the flyback. You have to take the front cover off where the speakers are. Trace them and unplug them.
Posted on Nov 08, 2008
ladywinn
  • 5138 Answers
SOURCE: Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Posted on Feb 19, 2009
Tip
Diagnosing and repair of TV High Voltage problems.
Your TV is dead or perhaps the turn on relay clicks and immediately clicks again, followed by your standby light blinking a specific code. For each TV the code is different. To find out your code google "(your brand name) error codes". This should return the listing of codes for your unit. Check the code to see if it is the high voltage section with the problem.
The hardest working section of any TV is the high voltage section. This does not apply to flat screens and DLPs only CRT projection units and conventional direct view units. The flyback get hot and is made of many windings of very thin wire which is only shellaced to insulate it. Over time the windings coating breaks down and the windings short together. This can happen in as little as several years. Once shorted there is less resistance and the current being pushed through the flyback increases. This overloads the Horizontal Output Transistor which gets hot and fails. This in turn causes the low voltage power supply to detect the overload and not allow the unit to start up, giving you the error code blinks.
The flyback is generally near the rear of the unit and is cylindrical with large rubber wire or wires if projection coming out of it and going to a rubber cup on the CRT or CRTs. Near the flyback will be a large heat sink with a large transistor mounted to it. With the set unplugged check the HOT with a DMM on diode scale for resistance. The leads of the HOT should be marked on the circuit board (C= collector, B=base,E=emittter). If the HOT has 0 resistance between all the leads it is shorted and you need to replace both it and the flyback.
You should be able to obtain both parts at http://www.encompass.com or http://www.shopjimmy.com . Unsolder both parts and remove from the board. When installing the new HOT be sure to clean off the heat sink and apply new heat sink compound available from the parts supplier. The flyback also will have two additional wires to remove and replace. One goes to the CRT board and may plug into a plastic box on the CRT jack or be soldered into the board depending on the model. This process should be self explanatory if you study it a while.
Depending on whether you have a projection TV or a Direct View TV the procedure is a little different. I will describe the procedure for a direct view TV first.
The 2nd anode lead (large red rubber wire going to the CRT) is plugged into the CRT and may have 48 kilo volts on it! Discharge the potential to the ground strap (bare wire going around the CRT) using an insulated screwdriver and a wire with gator clips on each end. If the CRT was storing power there will be a spark and loud snap when you make contact. Once discharged the tube is safe. Pull back the rubber boot and remove the wire from the hole in the tube. Install the new flyback wire. Solder the new flyback to the board reassemble everything and turn on. If you were successful the unit will start. You will need to set the focus and screen drive using the two potentiometers on the back of the flyback. Top is focus, bottom screen drive. Turn up the screen drive to get a picture. Tune to a channel with text. Turn focus to get the sharpest image. Tune to a channel which has both black and white in large amounts. Turn up screen drive until the black just begins to light up or starts looking gray then back it off slightly and you should be done with the unit. Be careful while adjusting the flyback as the set will have lethal voltages in it.
Now for the flyback on a projection TV. It will have 4 large rubber wires coming out of it. If the new one came with wires they should be removed at the HV divider block (located at the front of the set normally, just follow the wires to their end) if not they should be removed at the flyback. To remove at the flyback, which is the most common hookup, slide the rubber boot off the post and using needle nose pliers pry the cable out. It should have a bare end which connects to a clip at the bottom of the new unit. Do them one at a time to avoid getting them wrong. When done you may have to adjust the focus and screen drive but it will be on a separate box called the HV divider block usually near the front of the unit behind the grill. Same process as listed above for the direct view set. If your unit still does not run you may also have to replace the HV divider block. All safety rules apply here also.
That should conclude the repair and if successful your set will work. If the unit still does not work go to my tip on troubleshooting at http://www.fixya.com/support/r4425277-basic_direct_view_tv_troubleshooting which explains the basic troubleshooting method to find any problems in standard televisions.
Thanks for using FixYa.
hardrocko
on May 23, 2010 | Televison & Video
R56wh78 rca 56 in.. need help .. was wondering if any one new how to remove the wires from the flyback.. the ones that sit on the flyback itself.. or do they even come off.. i am replacing my whole...
your model has the 270125 which has sealed wires in the flyback which cannot be removed they have to be removed from the other end UP front and have to stay in the flyback.
Aug 17, 2011 | RCA Televison & Video
Wires going to flyback transfomer
Wires going into the flyback are not removable but are integral to the flyback. The three wires comming out the flyback are the thick red one (anode button) which attaches to the tube is removed by pinching the button to release the clips on the tube. The other wire probably white is removed by unsoldering it from the small board on the neck of the tube and the 3rd and last wire is probably black, this is the one you may have your issue. To remove this wire, you must disassemble the tube socket..look for two tabs..pry open gently and seperate. Then with a small jewelers you'll be able to release the black wire..hope this helps.
Jan 25, 2009 | Televison & Video
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
Flyback install
Sep 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback 259296
When you remove the rear panel look to the left side of the chassis and you will see the Flyback with the two wires coming out of the top one is a large thick red wire the other is a small wire. You can get a new replacement at the following link under 50.00 which includes free shipping and free support to help you install it by on line instant message with a repair tech.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | RCA D52W19 52" Rear Projection Television
Rca d52w20
You will need some solder wick to remove the old solder. You need to heat up the old sloder with a solder iron and while its molten touch the solder wick to the solder and the wick will absorb the old solder. You will need to keep trimming the solder wick end so it will keep soaking up the old solder. Do that to all remaining pins on the flyback. The replacement flyback will not come with the high voltage wire attached so you will need to remove the wires from the flyback. This is accomplished by twisting the wire 90 degrees while exerting upward pressure. Instalation is the reverse of removal. Let me know if you need additional assistance.
May 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips 60PP9202
Try removing the back panel and try to power up the set and see if you can determine if the popping sound is coming from the flyback, in case your not sure what a flyback is it has a large red wire coming out of the top of it. If thats where its coming from let me know as you may need a flyback.
Mar 27, 2008 | Philips 60P8342 60" Rear Projection...
Please help
sorry about that my new email is Willie@FORDTV.COM These are some of the hardest cables to remove. the black wire will come out but you have to pull straight up and with some force. with steady force not quick jerck or you can break the wire. the big red wire usally has a clip gromet under the boot slide the rubber boot up the wire. remove this gromet is difficut. i usally break about 75percent of the one i try to remove. some technicians say freeze spray helps..i never use it the groment holds the wire in the hole there are two slots on the side you that push in.. question did the new flyback on the board have a groment..just in case break the old one?
Feb 07, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
