I am trying to install a gforce chip
SOURCE: Where is the Intake Air Temperature Sensor or the
The air temperature is taken between the air filter and the throttle body. Look in the roof of your air cleaner box. (usually 2-pin plug) After the air cleaner, the tube that sends the air to the throttle body has the mass air flow sensor in it.(usually 4-pin plug)
SOURCE: 2006 Jeep liberty sport remove door panel driver side
2005 jeep liberty,the key will not unlock the driver side door and the power lock will not unlock the driver sider door.
SOURCE: power mirrors stopped working
If both power mirrors stopped working at the same time it has to be a fuse or the switch has come unplugged, or it has become defective. mike
[email protected]
SOURCE: 2003 jeep liberty sport 4x4
It means that your transmission is probably slipping check your fluids and have you transmission filter changed also change your plugs your check engine lite should go out. Please rate me any further assistance you can always ask me.
SOURCE: LOCATION OF IAT CONNECTORS ON JEEP LIBERTY
which engine? if it is a 3.7 Liter then the IAT sensor is either in the air cleaner box or in the air intake flex hose from the air cleaner to the engine. see photo of IAT.
