Question about Lands Phones
How do i get my phonebook numbers to display on my cars hands free
I have my numbers in my phonebook but when I go to phonebook in my car the display says no numbers found
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
You have to check if your phone is compatible with the vehicle systems. Many are not or are partially compatible. The owner's manual or car manufacturer web site should have that information. If not, go to the dealer. They can look it up for free.
Posted on Sep 13, 2014
SOURCE:
All my incoming calls are displayed as unknown number even for people saved in phonebook!
hi friend, this problem occurred. bcoz, same numbers are saved two time in your phone book. so, delete those numbers. which has saved as unknown name in your phonebook. go and check it.
Regards: Rakesh
Jan 31, 2011 | LG KS360 Cell Phone
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Samsung Cell Phones
When i connect my veiwty to my parrott i can make calls if i use the phone but if i go to phonebook on the parrott it wont bring my contacts list up can any one help
change the parrots phone book settings to use the parotts phone book. you will have to wait 5 minutes for the phone book to load then program your voice commands.
Apr 04, 2010 | Parrot Hands-Free Car Kit with LCD Display...
Good afternoon, I have a Parrot CK3200, and a 3G Iphone, and am completely unable to sychronise my contacts to the Parrot. The devices pair perfectly well and, when a call is made from the phone, the...
If you have had the parrot a long time you will need a software update, this can be done from a laptop with a bluetooth dongle. Try Parrot.com/support you can also try sending the contacts via bluetooth to the parrot one by one.
Feb 07, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Parrot 3100 LCD is not taking phonebook from Samsung SGH A501
You phone is not compatable with the parrot to recieve contacts, only for calls, this is a problem with lots of Samsung phones.
Jan 01, 2010 | Parrot Hands-Free Car Kit with LCD Display...
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Hands free feature
I had the same problem : seems that the reason for this, is a double (or multiple) input in the phonebook with the same name : whenever the phone tries to send the contents of the phonebook to the car GPS, it detects the "double" (or multiple) input(s) and does not know what to do with it. Thus the phone blocks ("hangs") and reboots itself. A simple remedy for this : just remove the double input(s) from the phonebook and the problem will be solved.
Sep 06, 2008 | Samsung Modem Configuration Software...
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Lands Phones Logo
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
