Question about Haier Dishwashers
Fitting new door seal to Haier DW12 Dishwasher
Can anyone let me know how to do this, do I just remove the interior door panel and then put the new seal on and how do I put new seals on the inside of the casing around the door?
Thanks
aborcass
  • 2651 Answers
SOURCE: leaking around seal in the center of dishwasher
the white hook peice is just that, a clip to hld down the motor. as you reinstalled you must have twisted or shifted housing to "pop" that clip. no worries easy fix. remove the lower rack and give alook at the motor assy from within ther tub make sure the black gasket is pushed completely down flush with the bottom of the d/w. applying pressure to top of motor assy will push it flush. the motor simply rests in the opening . the clip holds it in place from underneath, unable to find a pic but there a 3 in total under unit.
Posted on Nov 06, 2008
Testimonial: "Exactly what it was."
SOURCE: Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Posted on Nov 08, 2008
  • 41 Answers
SOURCE: Black Mold growing inside dishwasher
this is an easy fix use 1 part bleach to 10 parts water and wipe down this will kill the mold you may need to do this several times
Posted on Dec 09, 2008
  • 148 Answers
SOURCE: dishwasher seal issue
I use ge silicone clear sealant it is flexible adhesie that can handle water and heat
You can get this at Ace or big box stores you do not need a big tube
FIX:
1 Open dishwasher door
2 gently pull rubber seal away from dishwasher guide You do not have to remove the entire seal unless it is loose just keep pulling until you feel the seal staying on dishwasher
3 put a small amount of clear sealant on loose seal(side facing housing) and small amount on dishwasher guide ( dip your finger into water so that it does not stick to your finger)
4 press the seal into place on dishwasher housing
5 wipe excess with a damp cloth be sure you do not get any on seal side that faces dishwasher door
6 Allow to dry over night
Good Luck
Posted on Jan 02, 2009
skrbin
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
We have a Haier DW12-PFE2-U dishwasher thats 2 years old. The cycle stopped yesterday leaving an amount of water in the bottom and all of the program lights are illuminated with a recurring beeping sound...
Refer userr guide on page 21. It reads...
When all the programme indicators " J" blink.
Have you checked whether:
the door is closed properly.
The door switch could be the problem or the door seal is pushing the door open. May need replacement.
May 19, 2011 | Dishwashers
Hi threr I have the following problem with my Haier DW12-EFM dishwasher: The dishwasher seems to operate properly for the first several minutes untill program selector knob stops betwin position 2...
This is either a fault with the temperature sensors or the timer it's self, Not a simple one to diagnose without some general knowledge of how these circuits operate
May 14, 2017 | Haier 24 in. ESD100 Built-in Dishwasher
Hi. My dishmaid dw12 sometimes leakes water. ive checked the water inlet and draing and its not that. what could it be
If the water is appearing at the front of the dishwasher during use, it's most likely that one of the door seals needs replacing.
There is a white panel, about 4 inches high, below the door. Stand to the side of the washer, open the door about half-way, and have a feel about on top of that lower panel. If it's wet, it's almost certain one of the seals is perished - usually the bottom door seal. This seal isn't visible like the goal-post seal that runs around the sides and top.
Also, food waste can build up on or under the seals and cause leaks.
If the water is appearing from the back or under the washer, then further investigation is needed and you may need an enginner. It's hard to be definite as you haven't been very specific about where and when the leak occurs.
Oct 18, 2010 | Dishwashers
DW12-PFE2-U lights up but will not start program
Well first of all you can check out the door switch - The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Your switch also may be locked in place by a locking clip. If this is the case there should be a button or a lever that you can press or pull, which will release the switch and it can simply be removed. Please post comments for further help or information........
Good Luck!!
Thanks
Jun 07, 2010 | Haier Dishwashers
DIshwasher drain clogged Haier dishwasher model DW12-PFE2-E
Remove the drain hose from the sink drain assembly and force air into the hose--The clog should spit out into the washer cabinet. Make sure the drain hose doesn't have any kinks or sharp bends. Hope this helps.
Nov 21, 2009 | Dishwashers
I need help installing the front passenger window in my 1990 acura integra rs. can anyone help?
Remove the interior door panel being careful with the switch wiring. You might have to hook up your power window switch over and over to gain access to the (2) 10mm bolts holding the window on the regulator arm.
To put the window in, be careful when fitting it in that you don't get stuck and end up braking the cast/plastic guides that are fastened to your glass. Get it in there, make sure it's lined up in the track and install the 10mm bolts. Don't put the entire interior panel on until you test it. You might have to hold it a little bit while you test it because the inner weather seal kind of helps keep it stable while;e going up and down. Good luck.
Oct 02, 2009 | 1990 Acura Integra Hatchback
I have a DW12-PFE2-2 the dishwasher tablet does not dissolve,it is still in the dishwasher detergent dispenser after wash has finished?
HI Accumulated detergent from prior washings can cause problems with the soap dispenser. Buildup can get into the soap dispenser and interfere with the spring that triggers the flip-out tray, or it can slow down the pivot action of the tray. If the dispenser is not opening, first make sure you aren't loading the machine so dishes or pots and pans are touching the dispenser, and that dish racks aren't blocking the dispenser. Also check to make sure the dispenser tray isn't cracked. If leftover detergent in the tray is almost liquid, rather than just damp, the tray may be damaged.
If you can't solve the problem easily, replace the entire dispenser unit. This is usually easier than trying to disassemble it and replace separate parts. Use a new dispenser made for the dishwasher. The screws holding the dispenser in place may be on the front of the unit, or you may have to remove the front door panel to get to the screws and make the replacement. Remove the old dispenser and secure the new one, connecting it in the same way the old unit was attached.
THANK U,,,,,,,,,,,,,,,,,,
Sep 12, 2008 | Haier Dishwashers
Dishwashers Logo
107 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
