Question about Continental Heating & Cooling
Cant find the owners manual for our Continental Electric portable AC unit - model CE14085. The drain light is on after having pulled the lower drain plug yesterday, there's a second drain screw off cap (still have the hose that came with the unit). How do I drain the water out of the unit?
SOURCE: narrow tube v. plug and cap?
If the unit stops working and some kind of a 'water level full' indicator appears then un bend it and un plug it and then let the water drain into a bucket.  If it continues to indicate that the internal water tank if full you may want to run a hose to a drain in the floor or into a bucket to let the water drain away and the unit keep running without stopping.
Posted on Sep 02, 2008
SpotBert
  • 231 Answers
SOURCE: need owners manual for Everstar Portable AC MPM1-10CR-BB6
Here's the 34 page manual from Danby Canadian website. =>
http://www.danby.ca/cms/uploads/products/en_manual/DPAC8020.pdf
Please leave feedback. Thanks.
Posted on Jan 03, 2009
  • 659 Answers
SOURCE: Getting Error E3 on my portable AC unit.
You need to get on-line and find the service manual for your unit. If the manufacturer doesn't have a down-loadable one, they will usually mail or fax you one. Once you have it, you can identify what the error code is and then work from there. It could be something as simple as a dirty unit. All these units are different in regards to error codes.
Posted on Apr 03, 2009
  • 3 Answers
SOURCE: On Everstar 10k btu portable a/c without auto evap. how do I tell unit to realease water to bucket?
http://www.supportuscenter.com/documents/MPK_Manual.pdf
Posted on May 23, 2009
SOURCE: i have continental electric model ce-pac1061-1 where can i find
Try your local machanic or even junk yard. Thsi will help.
Posted on Mar 22, 2010
Should i drain the water from my upright ac unit
All of them I have ever seen have a way to "get rid of " the water from condensation.
Ours has a plastic bucket that must be emptied.
We have another that has a drain hose that can be directed to your choice of drains.
All I have seen will turn themselves off if not emptied one way or another.
Jul 10, 2014 | Continental Electric Portable Air...
Power steering drain closely
Electric unit or manual ? if the later then no problem ,electric unit bit trickier as on the renault they are lower than the rack
Oct 18, 2013 | 1996 Lincoln Continental
I have a continental elec port. air. Not sure of model. Cools great but when compressor kicks on unit make a loud whistling noise. Cleaned filter no help.
although annoying, at this time i would not mess with it, the fan motor needs oiling (zoom spout oiler ) works the best .. you can find how in my other postings.. try running the unit on a lower fan speed... some cool is better than NONE
Jul 28, 2011 | Continental Electric Portable Air...
We are smelling an odor as if something might be burning. emptied the water through the hose, and it drained out well. How often should we drain the water?
Most of the AC units, that also act as a dehumidifier, have a indicator light, that tells you when to empty bucket. Since you didn't mention who the manufacturer is of your Portable AC unit of the model number, it's hard to be precise. Check your Owner's Manual or if you have misplaced it, check the water collection bucket frequently and empty as necessary.
Hope this helped you.
Jun 08, 2011 | Heating & Cooling
I have a CE-PAC1061-1 . I would like to know if it can be used as a dehumidifer. I do not have a manual.
All ac units are dehumidifiers. It should have a collection pan for the water it pulls from the air.
Aug 08, 2010 | Continental Electric Portable Air...
Our Air Condidition is not getting cold. Have no manual
check the wiring to thermostat sounds like the reversing valve is open letting hot gases through
May 17, 2009 | Heating & Cooling
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
Everstar portable air conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Sep 08, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
190 people viewed this question
Top Continental Heating & Cooling Experts
Tim Whalen
Fotis Papastamatiou
jasbo
jasbo
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
