Question about Sony Televison & Video
I have a philips surround sound and a sony blue ray how do i get surround sound if im watching blue ray
  • 105 Answers
SOURCE: Hello, I have the following :
try to check the settings
Posted on Aug 01, 2008
Dooms Day
SOURCE: surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Posted on Jan 04, 2009
  • 120 Answers
SOURCE: Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Posted on Feb 12, 2009
  • 1039 Answers
SOURCE: how to connect blue ray to philips 46" hd tv with direct tv service
Connect using hdmi or component video from dvd player to tv.
Posted on Apr 25, 2009
  • 9 Answers
SOURCE: Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Posted on Aug 21, 2009
I can not get my surround sound to work with my sony bravia HBD-E570 blue ray, while watching dish
I use HDMI cables for my blue ray DVD player, not sure if you do. If so, make sure surround sound is connected to your TV in the right jack. My surround system is old, so only uses RCA's (red, white, yellow). I plug mine into the audio out jacks (red, white) just below the HDMI 1 jack. Only the red and white are required for sound but also can use video (yellow) for higher quality. That is the main audio out. Plug into that and you should have all sound that is on your TV also sent to your surround system.
Aug 02, 2013 | Sony Bravia Kdl 46Ex700 46 in. TV
Want to activate HDMI and surround speakers without remote?
You will need the original remote access these functions, try www.sony.com contact customer support and the technical department, also try www.ebay.com type make and model of player and scroll through the list.
Jun 15, 2012 | Sony BDP-S550 Blu-Ray Player
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
I just bought the sony blu ray and cannot hook it up correctly to the surround sound, dish network and tv. The instructions given from Sony and Philips did not work.
Hi my name is Mike Houston of DISH Network, I see you aretrying to connect your Blu-ray to the surround sound system and you have DISHNetwork. I wanted to get a little more detail about the equipment to betterassist you, I was looking for the model numbers for the Sony and Philipsequipment to look at the configuration as well did you want any of the componentsconnected to the DISH receiver. I will leave you my e-mail to get the componentmodel numbers and will you be connecting it to our DISH equipment.
Oct 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
Aug 21, 2009 | Audio Players & Recorders
No surround sound, when playing blue ray films using ps3
Im guessing you are using a HDMI cable,
HDMI cables struggle to carry audio...
you will need a componet cable, this is basicly the same quality, and all you do is plug the audio cable part into the surround sound system and done.
Hope this helps
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Unable to get sound from tv to output from surround sound
as the tv stations that were being feed into the system were digital and the nput was actually analgoue 2 optical cables are required.
have tv sound and blue ray sound through surround sound when tv channels were changed to analague.
Mar 22, 2009 | Kenwood Audio Players & Recorders
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
