Question about Haier Microwave Ovens
How do i adjust power level
Can not get heat its running no heat how can i chech power level temp
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
There are no heat levels on a microwave oven, only power levels. I am not aware of any method of checking the power level except to boil water. Boil water at each level and time how long it takes to boil. The lower the power, the longer it should take. If there are no differences in the time, the oven is not functioning as expexted.
Posted on Sep 13, 2014
SOURCE:
Heated something in microwave and when opened door all power went out on microwave . cheched plug and there is power but nothing works
was it in a plastic container that melted and leaked throuogh bottom of microwave?
this happened to me so when i opened door itall went dead. i found a diode had blown as it was connected to the metal casing and replaced it. a plastic ice cream container melted. lo.
often when microwaves suddenly die its a short to earth somewhere
Dec 14, 2017 | In Microwave Ovens
Unable to adjust power level, the power level button on the control panel does not respond.
Try pressing and adjusting the power level before setting the cook time, or maybe before pressing start. Worked on my Panasonic
Dec 12, 2013 | Microwave Ovens
The oster model OM1201E0VG model, is not getting any power so the food is not heating in addition the adjustment of the power level does not seem to be operating. Please advise
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | Oster Microwave Ovens
Weak heat ???
Is the cooking level set to high? most microwaves you can adjust the cooking level. 10 is usually the highest. When you turn it on, there is usually an icon or indicator light that tells you you are cooking on high somewhere on the display
Dec 28, 2009 | Microwave Ovens
Do commercial microwaves have some sort of feedback loop designed to reduce power when they are insufficiently loaded? In particular, I'm using a GE Spacesaver for a little science experiment where we...
HI,,
ITS A PROBLEM WITH DISCONTINUE VOLTAGE..
USUELLY COMMERCIAL MICR WV COME WITH IMPROPER HEAT OUT,,
FOR EXAMPLE IF U PUT TEMP ON 100 FHT IT WILL GIVE OUT 80 FHT..
SO I PREFER A BRAND MICRO WV..
TNKS
RABBANEES
Nov 11, 2009 | Microwave Ovens
How do I adjust the power levelthen start the
Press "Power" until you get to the level you want. Then enter the # of minutes on the keypad (CANNOT use express cook times.) An alternating runnig hum will let you know the setting is working.
Nov 08, 2009 | Hotpoint RVM1635 Microwave Oven
How do i adjust the power level?
Hi Cindeet,
(I just responded, but it doesn't show-up - - my apologies if this comes thru twice).
Looking at the brochure at
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
on page 4, there's a control panel with the "Power/Temp" button - try pressing this, then using the knob to select the power level you want.
There's also a "Help" function - - upper right-hand side of the control panel.
Let me know how this worked for you - thanks in-advance.
Jon
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
...have Danby 1.0 cu. ft.
When talking about "Power Level", there is a misconception that the cooking power is being adjusted. This is not the case. The user is actually adjusting the duty cycle of the Magnetron. For instance at 30%, the Magnetron will be turned on for 20 sec. and off for 40 sec. A loud 60 cycle hum is usually caused by a shorted Magnetron. Thus the unit is not economically repairable.
Sep 30, 2017 | Danby Microwave Ovens
Microwave oven
maybe it is running. you can not change power while the unit is running. you can only set the power level while programming the heating schedule.
Feb 18, 2008 | Microwave Ovens
Microwave Ovens Logo
163 people viewed this question
Top Haier Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
DBurstiner
Are you a Haier Microwave Oven Expert? Answer questions, earn points and help others
