I need a replacment warm air extraction hose for a Proline sac100
I need a replacment warm air extraction hose for the back of my Proline sac100u Air conditioning unit. Or a contact of a UK supplier.
5 Suggested Answers
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
  • 124 Answers
SOURCE: Does the lemon law cover air conditioning units?I
as a general rule the lemon law does not effect acs. because the equipment colud be at fault, or the installer couild be at fault , or the installation or application coiuld be at fault, or the power company could be at fault or the ductwork inadquete or undersized? so there are so many variables that a new ac may not fix your problem so they rarely ever provide new.now lets discuss your insatller or dealer. why are they saying the rev valve is bad? let me say covs Changeover valves usually do one of three things. they stick in cool and wont shift so youare stuck in cool or sruck in heat. when energized you hear no kawhoosh sound and compressor doesnt change pitch. then they are stuck in heat or cool. what they do sometimes is stick halfway and that gives a coolish suction and a coolish line to the house but not real cold. the hot gas line is only warm and the discharge line is onlty warm. this means its stuck halfway. some times you can disconnect the fan run the pressures way up and gently tap the valve and it will free up. but it nay stick agagin. the valves in the compressor may also be weak and be misdiagnosed as as half stuck covalve.. you could close off the liquid line and see if the compressor cah pump down to zero . if it can't then compressor maY BE BAD .when the unit was installed did they put in a liquidline drier to collect impurities and protect the valve? its pretty unusual to see a valve fail and if to much heat is applied on replacement then new valve can be damaged. good luck , oh you have the option of requesting a different dealer if it is brand name like trane or american std with a parts and labor warranty. most dealers can honor the other guys warranty and get paid by the factory if you have lost confidence in your guy. i am sure you know right away if you got a budget jack leg job or a pro . good luck.
Posted on Oct 24, 2008
SOURCE: Need replacement hose
online http://www.amcorgroupusa.com/mm5/merchant.mvc?Screen=PROD&Store_Code=AMCOR&Product_Code=1105-032AG1&Category_Code=ALSERIES_PARTS
Posted on Jun 26, 2009
  • 43 Answers
SOURCE: USER MANUAL
safemanuals.com/brand-user-guide...manual/PROLINE
Please visit the link
Posted on Jul 02, 2009
Air is cool at first then powers down and get warm air and its hot in back around hose
Need a technician. There are to possibility or the liquid that work the air conditioner need to be replaced ore the pomp dot work very good.
Sep 11, 2015 | Heating & Cooling
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
Aug 30, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
My '04 blazer has been revving erratically when I start it. Goes back to normal after a couple minutes of warming up, but when I drove without the warmup it was revving up on its own even when I h
I had an 04 blazer. There is an undocumented problem with leaks in the intake manifold. The original gasked was low quality. I would expect that you have a vacuum leak in the intake manafold. My problem was a coolant leak. Replacing the manifold gasked fixed it.
If not this, make sure you do not have any creaks or opening in the air hoses that fed the throttle body.
Apr 14, 2013 | 1996 Chevrolet Blazer
Have 2000 VW Beetle heater not working. Had a flush done and replaced thermostat. At first thermostat would not open but after quite some time running it did open and began blowing rather warm but not hot...
It is very possible that there is air in the Heater hoses and it needs to be "Burped". With the engine COLD, remove the radiator cap and locate the Heater core hoses (there will be 2 hoses close together - In and a out). It is also possible the thermostat could be installed backwards.
Nov 16, 2017 | Cars & Trucks
Can anybody tell me where I can get spare parts for a proline air conditioner unit please. Im after a main input hose, drain hose and an instruction manuel.
Here's a link to a company that stocks Proline parts. It's worth checking out, as there are very few places that do stock Proline Parts. Plus, they also have a repair section to help you out.
http://www.apwagner.com/index.php?main_page=index&cPath=1_1137
Apr 07, 2011 | Heating & Cooling
I have an 1994 ford escourt wagon LX..i have replaced the thermostat and housing back flushed the whole system threw heater core..the air still doesnt blow hot enough air to warm the car up inside..this...
Does the air coming out of the vents change when you move the temperature control knob? If you can't feel it, you should be able to hear the change
Feb 13, 2011 | 1994 Ford Escort
I have an 1994 ford escourt wagon LX...i have replaced the thermostat and housing and back flushed the whole system..the air still doesnt blow hot enough air to warm the car up inside..this needs to be...
Hi hope I can help.
Go in the engine compartment on the passenger side fire wall,
you will see two 3/4 inch hoses.
run your engine up to temp
Then place your hand on the two hoses. (heater core hoses)
Both hoses should be warm.
If one is hot and the other cool your heater hose is clogged.
You can try to flush it by removing the hoses and flush it with a garden hose.
hopes this helps .and keeps your warm.
Please leave feedback thank you FixYa
Feb 09, 2011 | Ford Escort Cars & Trucks
I have a amtrol proline pressure tank model ca17255 with air in the water part of the tank. how do you get the air out. thanks
the water heater should have a value on it. connect a hose pipe to it, run hose out door or window, then open value. need to open bathtube faucet.(cold) let it run until air gone, then go around and open all cold and hot faucets one at a time to remove all air in lines.
Aug 20, 2009 | Water Heaters
USER MANUAL PROLINE SAC100
Jul 02, 2009 | Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
