Question about Uniden D1685 3 Cordless Phone Answering System With Speakerphone And Handsets T
How do i get the phone to ring
How do i remove the silent feature and get my phone to ring
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Find the MENU button on the handset, then select Handset Setup. Scroll through the menu to locate the option you need to change.
Posted on Sep 13, 2014
SOURCE:
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
My uniden phone is on silent mode and i cannot get it to ring noma;
For most Uniden phones, you can cancel the Silent Mode by pressing and holding the # key for ~5 seconds on any handset. (The key is below the 9 on the keypad.) You will see the icon disappear when you hold the key for long enough. This method also enables the Silent Mode. When it is enabled, you have the option of pressing a number key to limit the Silent Mode to a specific number of hours.
Note: other Uniden models have a Do Not Disturb option. The feature can only be enabled or disabled at the base.
I hope this helps.
Aug 28, 2015 | Uniden Lands Phones
How do you turn off Silent Mode so you can hear phone ring?
For most Uniden phones with this feature, you can toggle silent mode off by pressing and holding the # key (below 9) on any handset. (Some Uniden phones have Do Not Disturb which is controlled by the DND button on the base.)
I hope this helps.
May 11, 2015 | Uniden Cordless Phone
How do I remove "Do Not Disturb" from the readout so phones will ring for incoming calls?
What model Uniden phone do you have? Most of the Uniden phones that support Do Not Disturb have a DND button on the base. Press and hold that button to toggle the feature on and off. (If the answering system was off, it will turn on when the DND feature is engaged.)
Other Uniden phones have a Silent mode that is enabled/disabled by pressing and holding # on any handset when the phone is in standby.
I hope this helps.
Apr 15, 2015 | Uniden Lands Phones
It is silent mode. will not ring using my ring tone
Silent mode keeps your phone from ringing using any ring tone. Take your phone off silent.
Mar 07, 2011 | Cell Phones
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
The handset is on silent (so doesn't ring). How do we make it ring? (Can't find our operators manual)
Feature * 80 adjusts the ring volume. I should think that would do it.
Apr 13, 2010 | Lands Phones
Phone rings only once then is silent. How do we
This is a symptom of a feature that has been activated. It could be the call is forwarded, it could be the voice mail is programmed to pick up on the 1st ring. On some systems ext's can be programmed to ring elsewhere after a set number of rings. The do not disturbe feature could be activated. If it is an outside line, call it from your cell and see what you get (voice mail-continious ring-another ext etc.) Find out if it does it on an in houes intercom call. Look for a DND button the phone...is it lit up? Does the display show calls forwarded or DND? Hope this helps. Good luck.
Mar 24, 2010 | Lucent Merlin Legend MLX-20L Phone
My ge 6.0 dect phone won't ring and shows a music note with a slash through it on the display even after i set the ringer on high volume
DER. Ya have it set on silent. While on a call use the up/down keys & it should de-activate silent feature. Why would ya set it like that 1stly?
Jul 03, 2009 | Thomson GE 27907GE1 Cordless Phone
Uniden D1685 3 Cordless Phone Answering System With Speakerphone And Handsets T Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
