EDENPURE 2013 GEN4 1000 Quartz Infrared Heater Logo
D
Don Masse Posted on Sep 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my Edenpure Premiere heater keep telling me that it is not level? Why does it keep shutting off and turning back on?
I have used my level to check it and it is level. I have cleaned the air filter and then unplugged it and plugged it back it and still comes up with not level. I have also moved it to a different place in the room and still doing the same thing.
Matthew Quinn
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 12, 2014
Matthew Quinn
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4804
Points
I am having the same issue but mine will heat up for 5 minutes the first time and then shut down and turn non stop. My unit is only 7 months old and was used for two months. Company said I had to return it for repairs
dgskroch
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Sep 17, 2014
dgskroch
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
13938
Points
34
The level sensor inside might be loose or fell off. Call the company.
Raylin Sutter
Level 2:
Sergeant:
  • Expert 107 Answers
  • Posted on Aug 26, 2015
Raylin Sutter
Expert
Level 2:
Sergeant:
Answers
107
Questions
0
Helped
277376
Points
610
Your heater may be broken or have some sort of glitch. Our heater had some issues last winter and was acting up like that. We called in the heating repair specialists and they were able to get it working properly in time. Have you tried asking the experts about your issue? Stay Warm with Heating Repair Service near Mount Joy PA
jabberwoky
Level 3:
  • Master 739 Answers
  • Posted on Feb 12, 2015
jabberwoky
Master
Level 3:
Answers
739
Questions
0
Helped
229840
Points
3082
Dgsroch is probably correct. other possibilities are that the internal level sensor has malfunctioned (shorted) or that wiring to the sensor has become faulty (burned, shorted, broken, or disconnected in some way) You may need to replace the sensor, or repair the wiring, BUT... if the unit is under warranty? I would send it to the manufacturer for repairs. Probably less headache than trying to DYI.
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
I just changed heating elements in my edenpure usa 1000 and now it keeps tripping my power strip ?
Check to make sure that the elements are weird in the right place.
See if there is any loose screws or metal on metal.
The elements might be bad
If wired wrong it may not be making a proper circuit.
Check the pcb boards to see if it is touching metal on the bottom side of board.
If you put a screw in the wrong spot it may be grounding something out.
Check all wires for bare spots
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving.
If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner.
Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light.
Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position.
Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear.
Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear.
If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock.
If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Heater Shuts Off after 2-3 minutes
Does it matter if the thermostat is 120v or 250v?
1helpful
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
2answers
The fuse keeps blowing inside the edenpure heater
Generally speaking, fuses blow when too much current passes through them. Typically this happens when there is a short circuit some place. a connector or bare spot in a wire touching ground, a bad component on a circuit board, a bit of conductive debris on a circuit board all can cause shorts. If the fuse blows, it's doing its job to protect you from a problem you have yet to find.
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Top EDENPURE Patio Heaters Experts
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an EDENPURE Patio Heater Expert? Answer questions, earn points and help others
