Have tried to download pictures from my cannon digital ixus camera to the printer only the top half of the picture is printed leaving the bottom half clear I have not had this problem before I have renewed the cassette to no avail any ideas
SOURCE: Cannot Download pictures from camera to computer
I tried different card and it worked. I'm waiting to contact SanDisk to solve the problem. Hate to lose all the pictures. Thanks for your help.
SOURCE: Can not download pictures on
Start deleting pictures base on how good they are, importance and priority. Then by trial and error delete 50 pictures, download; 100 ... 200. Finally it download ... after 10-15 seconds wait. Total pictures deleted 1700 out of 4200. So there is a limitation on this type of camera with a 2GB chip, you have to stop taking pictures and change camera
chip when the total count reach 2500 + or - 50 pictures.
SOURCE: Kodak EasyShare Printer Dock Series 3
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
SOURCE: Overall pink cast and pink stipe at top of all images taken.
the pictures not clearly in the lcd. It is like pink or white colour
