Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
My monitor says cable not connected
The cable is DVI at one end and HDMI at the other. DVI - plugged into the monitor, HDMI plugged into the computer. Neither the computer nor the monitor recognize each other.
  • alexa_sunshi Jul 03, 2009
    Hmm, there is only one cable, that has at one end HDMI and at the other DVI, so it must be plugged in at both ends.
    Now it's working. I think the cable, because it was new, had the pins at the HDMI side covered in that golden polish. I plugged it in and out a few times and then, the monitor recognized the computer. But since the computer didn't recognize the monitor, I left the cable plugged in and I restarted it. After restarting, the computer has also recognized the monitor. Now it's ok.
    Sergeant:
  • 258 Answers
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Posted on Jul 03, 2009
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
How to connect the HDMI Cable from monitor to Computer which has no HDMI ports?
You need a purchase a new cable. I assume your HP pavilion is under 5 years old. And you should have a white DVI port in the back for a monitor. If you do have that connector, then all you need is a DVI - HDMI cable, make sure the DVI will be to the computers end and HDMI to the monitor.
for example this cable:
http://www.amazon.com/AmazonBasics-HDMI-Adapter-Cable-Meters/dp/B001TH7T2U
Dec 31, 2013 | HP Pavilion Computers & Internet
No pitcure, but the power light is on
My first bet is on a dead power-inverter. Get it replaced if you can still see a very darkened picture. OR... if there's no picture at all, call warranty support or take it to a repair shop. Also, if you're fine with electronics, I can guide you step-by-step to diagnose the fault.
Mar 06, 2011 | Samsung SyncMaster 910MP 19" LCD Monitor
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
What type cable do I need to connect the monitor to a hp xw4600 computer?
An out of the box HP xw4600 has a NVIDIA Quadro FX1700 video card which uses a DVI cable. You have to make sure your monitor supports DVI. A WHITE connector is for DVI while a BLUE connector is for VGA. Some monitors have both while many older models only support VGA.
Oct 29, 2010 | HP xw4600 Workstation Linux Installer...
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
How do I hook up the moniter to the CPU?
First figure out what output video the computer has. These days it can be VGA, DVI, or HDMI. Then determine what video inputs are on the monitor (same list). Then plug in the desired cable. Many monitors only come with the VGA cable. If you do not have a VGA port on the computer you would need a DVI to VGA adapter to use that cable. Otherwise buy the DVI or HDMI cable. (DVI to HDMI cables exist if you have HDMI but no DVI on the monitor and only DVI on the computer. However, you need to check your video specs closely. A Single link DVI is different than Dual-link DVI and the cables are not interchangeable.)
Once the data and power cords are plugged in, power up the monitor and then the computer. The computer should find the new hardware and install (or ask for a disc to install) the drivers.
I hope this helps.
Mar 20, 2010 | Gateway Computers & Internet
Im trying to use my TV as my monitor for my pc?
What problem are you having? The connection should be fairly straight forward depending on your computer's video out. You can use a VGA cable, DVI to HDMI (check your graphics card manual for single link or dual link on the DVI side), or component video (even S-video). If you have HDMI out on the video card, use an HDMI cable. If you want to connect to the TV's speakers, you need at least an 3.5 mm audio cable (or 3.5 mm to RCA audio).
The DVI cable can be either a DVI to HDMI cable or DVI to DVI or HDMI to HDMI with a DVI to HDMI adapter at one or the other end.
I hope this helps.
(you will need to go through the input modes to find the signal. Some TVs need to be on (with no signal) before the computer is turned on.)
Feb 22, 2010 | Protron PLTV-3750 Television
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
2,049 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
