My minidv camera has the following problem. started to shoot everything was fine, but then look at the record go 4 black lines, run it through the TV and again work,a new tape and again .Please help
Sounds like your iris is shut. Try giving the camera a good smack with the palm of your hand near the lens. That should free up the iris. Can you view previously recorded tapes??? If so your video board might be bad. Hope this helps.
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
It could be that the CCD unit is going bad. You should take into a camera shop to get a professional look at it. Usually that type of taping is caused from a bad CCD.
The most common cause of this is a failed image sensor. Usually the playback mode will let you view pictures taken before the issue happened just fine and you will also be able to view the menu system just fine. When viewing the screen in an image taking mode, however, there is typically discolorations, horizontal or vertical lines, image bluring or distortions, or simply a black screen.
This situation, if caused by the image sensor, has to serviced and cannot be fixed by the user. If you are within your one year warranty and no user damage has been done to the camera, the camera will be fixed at no charge. If beyond the 12 month period however the customer may opt to have the unit repaired at a cost or take advantage of the Canon Loyalty Program and upgrade to refurbished S3 IS at an alternate discounted price.
make sure camera has this function first,Easy way to check is to see if top of camera has a record botton where play,ff,rew,stop are..Put camera in VTR mode then hok up cable to tv ..if no signal is comming thru,, check on camera menu for this function..LINE IN
