Hi
I also faced the same problem in my system make sure proper ventilation is provided it will solve the cracking sound the amp generates 40 deg C temperature if not ventilated
Just one channel or both? Have you swapped the speaker leads to see if the problem follows the speaker? (i.e. you're sure it's not a voice coil issue with the speaker)
Have you changed the input or tested the other inputs on the amp?
If you have done the basic trouble-shooting, then what's left is a circuit board problem. It could be a capacitor drying out and going "leaky"
SOURCE: main menu screen won't stay up on my krell showcase
If the main menu comes and goes off then it is possible that there is a fault in the processor memory. Try and reset with the given code- refer to manual, if not switch off set for about 6-12 hours and press down the panel buttons to drain off all residual voltage . this might help to reset.
Chances are that you have a "Leaking" capacitor in the final stage.
Time for the repair shop :(
