Question about Acer TravelMate 3260-4874 Notebook
My keypad got locked.how to open???? - Acer TravelMate 3260-4874 Notebook
My lagard lock safe won't open-no battery.
If internal battery is depleted and will not allow lock to open, hold a new9-volt alkaline battery on the contact points (large battery terminal to
large keypad contact, small to small) located on the front of the keypad.
Maintain contact, enter and valid code and turn keypad to open lock.
Lock contains a non-volatile
memory, even with batteries removed the lock will retain
all programming.
NOTE: You must maintain battery contact at all times throughout the
entire procedure.
Mar 15, 2014 | Safe International Digital Electronic Safe...
Where is the lock button located to disengage . so to open garage door with key punch?
The lock button is located on the wall control if your model has one but it does not affect the operation of the keypad. The keypad will work whether the lock is on or not.
May 15, 2012 | Sears Craftsman LiftMaster Chamberlain...
My keypad won't light up when door is locked whe you push lock won't light up green
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
I have a chamberlain garage door opener and we accidentally hit the lock button and need to unlock it from the keypad - is there a way to do this?
The lock button doesn't affect the keypad. In other words when the lock function is turned on the keypad will still work but your handheld remotes will not. I suspect you have other problems.
Jun 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Wall unit of garage door opener keeps flashing green. I believe it may be in the lock mode. Cannot open door from there, but outside keypad works.
IF THE KEYPAD AND REMOTES WORK IT IS NOT IN LOCK MODE.
DO YOU HAVE THE POLARITY BACKWARDS???
IS IT FLASHING A FAULT CODE???
Jun 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad locked of Google Android phone
Open and remove the battery. Replace battery and close. Hit the Power button
Mar 09, 2009 | Google Android
Samsumg C300
ok... your keypad flex might get loose or dirty keypad contacts inside or check your volume if it get stuck... or
if you can open your phone, checks its connection or keypads contacts get dirty...
hope that solves your prob...
Oct 29, 2007 | Samsung SPH-i500 Handheld
Acer TravelMate 3260-4874 Notebook Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
