Question about Maytag Refrigerators
My maytag fridge is getting too cold- even on the lowest setting? this has just started happening
  • nickdavis Jul 03, 2009
    sea breeze-thank you for your quick response.
    the fridge is a GC2225PEKW
    is this the defrost thermostat that is faulty?
    also - is it a job i can do myself- ie accesable? i am reasonably competent at doing work on electronic items.
  • Maytag Master
  • 4,655 Answers
Your thermostat is defective and if you would look for the model number bottom right corner of fresh food door I will tell what number to replace it with. Thanks, Sea Breeze
Posted on Jul 03, 2009
  • 2 more comments
  • John Tripp
    John Tripp Jul 03, 2009
    Here is where to look..Sea Breeze
    SITE=> http://servicepartstec.blogspot.com/
  • John Tripp
    John Tripp Jul 04, 2009
    Thank You, this is the most likely problem. Part number 12868513
    Un plug and have a look at the part for burn marks, loose connecrions or sighns of heat. This part is a 2 piece control board that signals temperatur and other functions. I will study the wiring diagram and see if there other possibilities. Sea Breeze
    Email=> appliancepartsse@yahoo.com cell# 864-812-1887
    http://appliancepartsandtechnicalservice...
  • John Tripp
    If you are reasonably competent at doing work on electronic items then you should have no problem. The people that concern me are the ones that put their hands on something and have no clue to the dangers. My experience in the last 40 years was mostly hands on. But I always admit if I don't know what I'm doing and do not blow smoke to make people believe I'm the king of science. I have worked with lasers and 20,000 volts dc voltage. Plant maintenance and been a supervisor. Over the years I have learned a lot. I have made mistakes and one of the worst was when I did not take the keys to a car of one my best friend. He was killed that night and I never get over the guilt of not demanding the keys. He was my former boss.
    Anyway we will get this fixed and if you stick with me and my team of experts we will get you a FixYa!
    Thanks, Sea Breeze
  • John Tripp
    John Tripp Jul 07, 2009
    Nick, Thank You for you Rate! If you need anything, you may contact me through my websites or appliancepartsse@gmail.com. It has been a pleasure to work with someone that will work with me and have the patience to go through the step by step way of diagnostics, Sea Breeze
My Maytag Dual Pro top freezer is running too cold.
freezer should be -15 and that is about 4-5 c on the knob
fridge should be around 4-5 C which is around +3 C
frost build up is from door opened too often , for too long or bad door seals
It is more prevalent when the ambient humidity is above 50% as it is the water vapour in the air condensing on the cold surfaces
Dec 13, 2017 | Refrigerators
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Maytag Dual Cool - fridge side too cold even on lowest setting - freezing vegtables
It's just as previous person, on warmest setting vegetables and meat are freezing in drawers
Apr 10, 2013 | Maytag MSD2651 HE Side by Side...
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Feb 04, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
Maytag fridge getting too cold
what happens when set on the warmest setting? still too cold then I'd think it was the thermostat. Good luck
Jul 03, 2009 | Freezers
Produce freezing
I had the same problem when one of my kids changed the setting of the chef's pantry (full-width drawer) to higher setting and everything started freezing. The setting should be at "lowest setting". Give it a try. deborah.
Feb 07, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Open Questions:
Refrigerators Logo
2,181 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
