Question about Phonic Helix18fw 18 Channel Mixer with Firewire
Phonic Helix Board sound problems
I recently bought a 24 channel phonic helix board. Although the board is picking up the signals from the installed microphones, when I plug in the speakers through the main output nothing comes out. It's only when I plug into the control room output that some sound can be heard but it is very quiet and distorted. How can this be solved? A step by step set up guide would be useful as the instructions are pretty useless
  • kev white
    kev white May 07, 2014
    Hi Barker, I'm having the same sort of problem but it's the ctrl room outs that has little signal but the main outs are fine. Did you get a solution to your problem? I'm thinking it might be a loose ribbon cable inside?
  • 29 Answers
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Posted on Aug 01, 2009
I have a phonic 410 powered system but the sound dont work since yesterday, what can be the problem?
If it's not lighting up check the fuse. If it is lighting up, try all four channels to try to isolate the problem. If it is indeed dead, it will need to go to the shop. However, get an estimate first as it may be more cost effective to replace it instead.
Jul 03, 2016 | Phonic Music
Operations manual
Here is a link to your manual, hope it helps.
http://www.phonic.com/en/helix-board-18-firewire-mkii.html
Nov 27, 2013 | Phonic Helix18fw 18 Channel Mixer with...
My power supply in my phonic helix mkII 24 board is blown, it was messed up in a power surge, I have tested the remaining connecting parts and everything else is fine. I contacted phonic and they dont...
Usually it's the electrolytic caps that go in those, they basically "cook" and dry out, a power spike just pushes them over the edge. I've also had this problem with mine & 2 12 volt switchers for my HD and for the satellite had the same fix. I added a fan which helps. Another solution is to go to a second hand store, find 3 power suplies (15v,15v, 5V) and put them in place of the existing one. I am considering that myself as the firewire packed it in again last month and I had to jump over to the other 5v regulator to get it going again, even tho it was only 0.2 v short! Cheers, Sandrine
Jun 20, 2011 | Phonic Helix18fw 18 Channel Mixer with...
I get a distorted sound from my speakers throug a Phonic Helix Board. It is connected on a PC through Fire Wire. The distortion is also there while using microphones or other inputs (CD-players etc.). It...
Hallo landgenoot ;)
It seems it is a power supply problem; distorted sound, no meters, solo buttons not working, headphones low level and distorted. One of the power supply voltages might be too low or even missing. The Helix series mixers use mainly 4 supply voltages: + 15 V and - 15 V for the analog part (audio), + 5 V for the DSP and logic and +48 V only for the phantom power. If for example the + or - 15 V is too low, clipping of the positive or negative parts of the waveform (dependng on which voltage is too low) will occur. If possible, first measure the voltages coming out of the power supply. You could use a metal part of a jack as ground reference.
For the FireWire board an extra voltage supplied by the switched PSU is used. It is specified as +12,2 V, but I measured 14 V. This voltage is lowered to + 5 V by a resistor on the FW board and a 7805 regulator. (Not very efficient!) But as far as I can see, the FW voltage is not the problem here. I have some service documentation of the Helix series mixers (12, 17 and 24, so if you need more you can conatct me: frankdevries [at] versatel.nl.
Groeten, Frank.
Mar 18, 2011 | Phonic Helix18fw 18 Channel Mixer with...
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
You need to find a competent electronics repair person.
Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
I have a Phonic Helix Board 18 Firewire MKII. It is not picking up any signal from my computer. I have tried having a DI'd bass straight into it and it works fine. My PC recognises that the devise is...
It may be your old computer was running XP operating system and your new one Win7... There is a lot of incompatibility with different operating systems. You can try searching for a compatibile driver. If you cannot find one, the best thing might be to back-step to your old compatible OS and driver.
Oct 03, 2010 | Phonic Helix18fw 18 Channel Mixer with...
Pc not recognizing phonic helix 18 universal mixer
I have a Yamaha AW1600 and I had to go into my firewall settings and add it to my exceptions to allow the program access to my computer through the firewall. This may help. Thanks!
May 30, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Phonic Helix18fw 18 Channel Mixer with Firewire Logo
1,001 people viewed this question
Top Phonic Music Experts
Ben Armstrong
NOEL
NOEL
Are you a Phonic Music Expert? Answer questions, earn points and help others
