Question about LG KU990 Viewty
LG Viewty - lock key will not work at all
The lock key on the side of the phone will not lock or unlock. When it auto locks, I can't get into the phone. I've changed the settings so it no longer is on auto lock (by pulling out the battery) - but I can't put the phone in my bag in case I call people by accident. any ideas how to fix the button?
  • 3 Answers
Hi this happened to me, I put some WD40 on it, after reading about it on here. after two goes. hey presto it worked, good luck
Posted on Aug 06, 2009
Push the button in the left side of the phone.Is for locking the phone
Posted on Jul 21, 2009
Phone is locked. How do I unlock it?
With front of phone facing you. On the left side of the phone you will see two grey slim inline buttons, and or, keys. The top button, and or, first key is the UP/DOWN VOLUME key. The bottom button, and or, second key is the LOCK key.
(1) To UNLOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD UNLOCKED". You are now done.
(2) To RE-LOCK the phone. GOTO the LOCK key. PRESS and HOLD until you see the screen read out display "KEYPAD LOCKED". You are now done.
In Addition:
(3) To set AUTO-LOCK on the phone.
GOTO the MENU key. Located on the top left of the keypad on the front of the phone. The LARGE WHITE HORIZONTAL BAR directly under the word MENU on the screen readout. PRESS-IT ONCE. You now SEE the PREPAID ICON.
Next, locate the OK key, top center on the keypad. Directly below the middle of the screen readout.
Next, locate the UP-ARROW key directly above the OK key. By using the OK key PRESS-IT ONCE. Now you see the SETTINGS ICON.
Next, by using the OK key, PRESS-IT ONCE. Now you are in SETTINGS.
Next, locate the DOWN-ARROW key. Located directly below the OK key. PRESS-IT ONCE. PHONE SETTINGS should now be highlighted for you.
Next, by using the OK key, PRESS-IT ONCE. You are now in PHONE SETTINGS.
Next, GOTO the UP-ARROW, PRESS-IT ONCE. AUTO KEYPAD LOCK should now be highlighted for you.
Next, by using the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the OK on the screen read out). PRESS-IT ONCE. You are now in AUTO KEYPAD LOCK settings.
Next, by using the UP or DOWN ARROWS, GOTO the amount of minutes that you would like to set your phone to auto lock for.
Next, GOTO the OK key...(or...by using the WHITE HORIZONTAL BAR key, located directly below the screen read out). PRESS-IT ONCE. Your screen read out will now display, "DONE"
Your phone is now set to AUTO-LOCK when your phone has been at rest for the amount of minutes that you have selected.
If you would like your phone to lock sooner in order to place it in case, pocket, or purse. Simply refer to (2).
Jan 31, 2014 | Alcatel Tracfone A382 BIG EASY No-Contract...
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
I have a k770i handset. yesterday i've updated the phone with se update service. now the phone is showing an error message on startup. insert correct sim card. when i tried *right*left left*right*....
hello.. Just check signed mode box in setting tab and use tab as interface and press unlock?repair key security code will change to 0000
Jun 22, 2011 | Cell Phones
When using the keypad, the screen auto locks after 2 seconds
on that phone there is a key board lock and unlock button on the right side of the phone second button fron the bottom.
try using that maybe it will stay unlocked
here is an online manual take a look at page 8
http://www.wireless.att.com/support_static_files/manuals/LG_Vu_CU920.pdf
Jun 06, 2009 | LG Vu CU920 Cellular Phone
Auto key lock locks every 10 secs despite changing settings off
First, do a power cycle. By turning your phone off for 10-20 seconds. Turn back on, follow these steps: . Put the auto key lock as fast as possible, so that the phone would turn off it's screen faster.
# Phone Settings > Security > Auto Key Lock > Change your time from this menu. It maybe saying 10 seconds now.
The reason this was set this way, was to conserve battery life. You can view: http://rukikenishiro.com/2008/04/how-to-save-battery-life-on-lg-ku990.html
to TIPS & TRICKS on conserving battery life, w/o having to jeopardize your screen.
Cheers!
Feb 03, 2009 | LG KU990 Viewty
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
Back side doors will not respond to auto key unlock and lock
Look inside back door frame and find child safety lock port. Set child safety lock to off setting.
Sep 18, 2008 | 2005 Chrysler Pacifica
LG KU990 Viewty Logo
767 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
