Is they a connection to fit a sata hard drive to my motherboard ga-8s650gxm thank you
    Problem Solver:
  • 19 Answers
I guess you have an ide/ata motherboard. There are pci converter boards to connect internal sata
hd's and adapters to use sata hd's externally via
usb.
Posted on Jul 03, 2009
I have a GA-81PE775-G motherboard, will a WD5002AALX (sata-3) be compatable with this
Hi, I have reviewed the Gigabyte Motherboard that you have mentioned. It has SATA (Serial Advanced Technology Attachment) supporting 150 MB per second. Which means that the Hard Drive of Western Digital (SATA 3) which you want to connect is compatible with the SATA port of your Motherboard.
However, the SATA 3 of your Hard Drive supports 3 Gb per second. Hence it will be working in 150 MB per second when you connect to your Motherboard.
Aug 09, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
Gigabyte GA-6OMM7E (GA-60MM7E) Motherboard have not display, please solution to me.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 07, 2011 | Gigabyte GA-6OMM7E (GA-60MM7E) Motherboard
Motherboard ga-k8vm800mnf do not find sata hard disc.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 06, 2011 | Gigabyte GA-K8VT800 Motherboard
Hi my friend: please help me for select HDD. 945GCM-S2L Max HDD Support? 945GCM-S2L <- this mainboard supported 2TR Byte?
This motherboard suports SATA (Serial ATA 3Gbps) meaning that it is compatible with any SATA hard drive. A 2TB (Tera Byte) hard drive is the highest capacity available on the market. This motherboard has 4 SATA connections so you can put up to 4 SATA hard drives into it.
Mar 15, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
I need mainboard driver for ga 8s650gxm ( sound , lan ,bios ide driver ) do you help me and show me how to donload them? best regards Mohsen
try visit this page:
http://www.gigabyte.com/products/product-page.aspx?pid=1658&dl=1#driver
just click the 'download' tab then choose download type and your OS. then the download link will appear.
hope this useful. best regard Riyan.
Feb 18, 2011 | Gigabyte GA-8S650GXM (GA-8S650GXM-P)...
PC will not boot up Memory checks ok but boot up hangs with curser flashing under dimm module 0 1 2 New 1MB ram module fitted (Crucial) still same problem
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 26, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
What kind of hardesk can installed to it sata or ide
This motherboard can use a SATA or IDE hard drive since it has connector for both SATA and IDE, but I suggest you use SATA hard drive for faster data transfer.
You can check this link for the complete specs for this motherboard.
http://techwiki.hardwarecanucks.com/product/2NTEyNzM3NzU4MA/Gigabyte-GA-8I945P-G/#spec
Aug 08, 2010 | Gigabyte GA-8I945P-G Motherboard
GA-8S650GXM FOR USB FRONT AUDIO PANEL
You will need the motherboards manual to help you with connecting USB_1, USB_2 and F_PANEL audio to you're case. If you do not have you're manual for the GA-8S650GXM you can download it from Gigabyte; http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s650gxm_series_e.pdf
You will also need Adobe reader installed to view the manual.
Gigabyte GA-8S650GXM main web site; http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1658
Turn to page 18. Number 17, F_USB1/F_USB2. Use the link provided below to help you connect you're front case USB wires to the motherboard; http://www.directron.com/installusb.html
Turn to page 24, for front audio connections. Keep in mind once you configure you're audio to function from you're cases front audio port you will not be able to use the rear audio port. Caution, most people find bumping any front case USB or audio cords break far too easely. To avoid breaking the front audio port, consider using a Y splitter for the rear audio port as shown in the next link; http://shopping.yahoo.com/p:StarTech.com%20MUY1MFF%20Audio%20Video%20Cable:1991733360;_ylt=Ah94ikZN9zDbTi2.arc45BkbFt0A
Hope you find this helpful.
Mike
Jan 22, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
I want to install audio and video drives for GA-8s650gxm
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1658#anchor_os
all the drivers are on the link
May 08, 2009 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
