2003 Saturn ION Logo
A
Anonymous Posted on Sep 12, 2014
Where is the thermostat on my 2003 Saturn Ion Level 3? I have no steam or smell but my needle on the dash keeps creeping up to almost the red mark. When i drive and don't idle it goes back down. Hel
Can I need a water pump. I am not leaking any water or coolant. I use Dex Cool coolant.
jamiem1416
Level 3:
Master:
  • Master 373 Answers
  • Posted on Nov 30, 2014
jamiem1416
Master
Level 3:
Master:
Answers
373
Questions
9
Helped
77939
Points
1021
Sounds like your electric fan is not coming on. Do you have heat? if not it might be thermostat, if yes, listen for or look and see if your electric fan is coming on
5 Related Answers
Anonymous
  • 109 Answers
  • Posted on Nov 19, 2008
SOURCE: MY SATURN VUE 2003 6 CYLINDER IS leaking anti freeze
The water pump is on the front of the engine. Does it look like a hose leak?
Anonymous
  • Posted on Jan 03, 2009
SOURCE: coolant light 2004 saturn ion 4 cylinder
I had the same problem. My 2004 Ion had 85000 miles on it. It was a bad sensor. The whole coolant reservoir tank needs to be replaced to fix the problem. This was covered under the extended warranty that we had. If you are doing this repair yourself, a hose clamp tool is recommended for simplicity.
Ronnie Wilson
  • 1596 Answers
  • Posted on Feb 09, 2009
SOURCE: where is 2003 saturn ion thermostat?
FACEING the ENGINE It is At TOP RIGHT SIDE Close to Master Cylinder takes About 1 hour to Replace Have Fun its a EASY One
Please Dont forget to RATE ME Thank You
  1. Drain the cooling system.
  2. Remove the bolts that secure the thermostat housing to the water pump feed pipe.
Remove the feed pipe
  1. Remove the thermostat and retaining sleeve, noting the orientation for installation.
Installation Procedure
Install the thermostat and retaining sleeve with the dimple placed into the housing slotImportant: Lubricate the O-ring with soapy water or coolant before installing the O-ring in the water pump.
  1. Install the feed pipe that connects the thermostat housing to the water pump.Notice: Refer to Fastener Notice in Service Precautions.
    1. Install the bolt that secures the water pump feed pipe.
      • Tighten the bolt to 10 Nm (18 inch lbs.) .
    1. Fill the cooling system.
Anonymous
  • Posted on Mar 04, 2009
SOURCE: How to replace coolant tank on Saturn SL2
The antifreeze tank is held on by I believe two bolts on the side. It's pretty easy to remove,
Just unbolt, remove hose and do the reverse with your new one.
As far as a replacement, I'd junkyard or ebay one. Lot cheaper, quicker, and easier than trying to get an aftermarket one and modifying to fit.
Anonymous
  • 1986 Answers
  • Posted on Aug 24, 2009
SOURCE: 2003 saturn ion 3 driver side window won't roll down
It may mean a bad switch, regulator, or motor.
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you can test the switch to see if it's the switch that's broken. If not, you can then pull off the weather seal and access the insides of the door
How do i check the transmission fluid in my 2007 saturn ion level 3 2.4 coupe
There is a RED color coded dipstick under the hood. The fluid is correct when level is in the crosshatch mark on the dipstick, while the engine is running at operating temperature. Use Dextron II fluid.
2answers
My 2003 Saturn Ion driverside floor board stay soaking wet
Hi Linda , you mite have a windshield leak ! You could possibly look under the dash an see if there is a water stain coming down the metal body inside ! If it were the passenger side I'd say you had a heater core leak .You don't have any unusual odors do you ? Like anti freeze ? Or does the windshield fog up when on defroster ?
2answers
2003 Saturn ion coolant light flashes on and off. No noises or burning smell. Not over heating and still has hot air.
Is it full of coolant if yes level sensor bad if not fill rad and overflow bottle to proper level and retest
No heat but blows cold air
Not if the engine is getting up to normal temp. Could be low on coolant or a problem with the heater core or a blend door under the dash.
My 05 spectra has an antifreeze smell and overheats, then the needle goes back down...seems to be no rhyme or reason, Antifreeze is full, but the Hot/Cold needle keeps fluctuating from the half mark to the...
if you smell anti freeze you have a leak. an overheating condition is caused by a bad thermostat, a bad water pump, clogged coolant system or air trapped in the line. have the coolant system pressure checked to locate the leak. it is probably very small that's boiling away before you have a chance to see it. and this is why the system appears full.
2003 Saturn, DOHC V6, burning smell in interior after car warms.
if the smell only comes on when the heater is on try pulling the blower motor mice like to build nests in the blower motor housing.
1helpful
2answers
2003 Saturn Ion 3 with warning messages coolant & power steering
You need to replace your ignition switch. If it has already been replaced then you will prob. need a BCM.
1helpful
Dash bezel
Turn the vents sideways and pull gently. they are a bit difficult, but they are just clipped in.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
