Home | T-Mobile | Sidekick II | T-Mobile Sidekick ID Unl...
T-Mobile Sidekick II
Problem for T-Mobile Sidekick II
T-Mobile Sidekick ID Unlock
By dukerb on Nov 10, 2007
Do you know how or what I need to do to unlock this phone?
Thanks very much,
Mike
Same Problem
May 25, 2009
-   i found a phone and i need a three didget code someone told me to let the battery run completly out and turn back on and it will have reset everything is that right -   Guest
May 09, 2009
-   i found a phone and dont know the code to it-   Guest
Apr 03, 2009
-   help unblocking sim card -   Guest
Feb 27, 2009
-   im having the same problem my id -   bearnathena
Feb 24, 2009
-   I NEED TO UNLOCK MY SIM CARD FOR MY PHONE -   JONATHANS372
Best Solution
posted on Aug 04, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i need the privacy three digit code for my t mobile side kick 2 and i will really appreciate in if you send me that on here or in my mail as mobbirdman2000@yahoo.com
Solution #2
posted on Jun 03, 2008
Very Helpful)
jolly man
Rank: Apprentice
Rating: 98%, 10 votes
**** my balls
it will work
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Mar 21, 2008
Very Helpful)
Necrobargain
Rank: Apprentice
Rating: 95%, 24 votes
I bought an unlock code off ebay, but all it does is allow you to make phone calls, the code you need to unlock the sim so you can text and get your contacts and such off it only tmobile has access too. And when calling them or the maker of the sidekick id they will all tell you they refuse to give out anything for the sidekicks, they being tmobiles bread and butter probably don't want other networks to be able to use them. So my question is, what not so legal ways are there for me to unlock my phone if tmobile and the phones manufacturer are totally unwilling to help? Can I like walk into a tmobile dealer and try and offer the dude like 20 bucks to give it to me or what?
Was this helpful?
Yes
No
Solution #4
posted on Apr 16, 2008
Very Helpful)
jayzzz
Rank: Apprentice
Rating: 97%, 27 votes
Try holding down Menu-jump to get to the emergency screen. Then hold down on menu-shift-Q and release. It will ask if you want to reset phone. IT WILL RESET AND DELETE EVERYTHING!!!!. It will be like new. Except sim. This works with sidekick 2, not sure with others.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #5
posted on Mar 05, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
from what ive read, you can only unlock your sidekick to function on other gsm service providers only (like t-mobile). sprint/nextel, for example, is not a gsm service provider, which makes it near impossible to unlock for. however, networks like at&t/cingular are, and should be pretty easy to unlock for. if you do use a gsm network, shop around for an unlokc code which you can type into your actual sidekick. best of luck!
Solution #6
posted on Nov 18, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
buy a unlocking code off ebay or something but only the phone option and texting will work, unless you have all ur numbers stored on ur sim card they will just get deleted. the sidekick works off of a diffrent network than most phones it doesnt actually store half the things on the phone but on the network. so you truly can unlock it and use it as a phone and a texting device but you wont be getting the full potential of the sidekick. personally i dont care id just use it as a phone but hey what do i know?
Solution #7
posted on Mar 10, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
that sucks i live in jamaica
Solution #8
posted on Jul 22, 2008
Helpful)
skylinez691
Rank: Apprentice
Rating: 91%, 6 votes
sidekick id reset code
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #9
posted on Jun 29, 2008
Helpful)
GlobalUnlock
Rank: Wiz
Rating: 84%, 211 votes
You need a unlock code, I have done hundreds of them successfully, goto SIDEKICK ID UNLOCK SOLUTION
(Please note that sidekick unlock will let you use SIM to make calls and text, this is permenant solution).
Was this helpful?
Yes
No
Solution #10
posted on Sep 01, 2008
Somewhat Helpful)
rkrager
Rank: Apprentice
Rating: 71%, 4 votes
I have a Dwade sidekick 3 and i went to network search found cingular. That makes calls, so then next u go to SIM CENTER. go there and go to Sim Card lock. Enable ur sim card (1111). After doing that change ur sim pin. This works you can txt and make fone calls thats about it. Let me know if this worked out for you.
Was this helpful?
Yes
No
Solution #11
posted on Feb 17, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you need to master reset it
Solution #12
posted on Dec 15, 2008
Helpful)
curve dick
Rank: Apprentice
Rating: 88%, 2 votes
i for got my 3 digit pin for my side kick
Was this helpful?
Yes
No
Solution #13
posted on Jul 04, 2009
Somewhat Helpful)
thatemokidsu
Rank: Apprentice
Rating: 75%, 1 votes
The settings that you need are below, Please let me know how it works out.
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Gateway IP 2: 000.000.000.000
Port 2: 0
Domain 2: blank
Service Type 2 WAP
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scr..
Was this helpful?
Yes
No
Solution #14
posted on Oct 27, 2008
Somewhat Helpful)
daboii234
Rank: Apprentice
i need help unlocking my phone. How do i do it sum1 help mE
Was this helpful?
Yes
No
Solution #15
posted on Aug 04, 2009
Not Rated)
mira18882
Rank: Apprentice
Rating: 0%, 0 votes
the pin is 0000 then change to new pin.works with my sidekick slide motorola..still figuring out how to discard t-mobile mms service.i cant seem to add my new network provider and set it as default?anyone can help me?
Was this helpful?
Yes
No
Solution #16
posted on Oct 14, 2008
Not Rated)
andrewright6
Rank: Apprentice
Rating: 0%, 0 votes
i need help trying 2 unlock my sidekick id... i need a 4 digit sim number
Was this helpful?
Yes
No
Solution #17
posted on Sep 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
t mobile is so stupid dont go with them..............
Solution #18
posted on Aug 26, 2008
Not Rated)
meliano25
Rank: Apprentice
Rating: 0%, 0 votes
i have a sidekick i id that i need unlock if any has a code to unlock and i will not lose my numbers pls let me know asap thank you
Was this helpful?
Yes
No
Solution #19
posted on Aug 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
there are stores that will unlock phones for you its more by word of mouth that you will find these kind of stores
Solution #20
posted on Jun 19, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i have the same problem and i really have to use this phone
Solution #21
posted on Apr 11, 2008
Not Rated)
Nauset
Rank: Apprentice
Rating: 70%, 1 votes
My phone crashed after taking the SIM card out and putting in back in while working with T-Mobile tech support. Now It will not turn on?? T-Mobile is unwilling to help and want me to upgrade to a new phone. Did they shut this down because of the problems they are having on the east coast???? Can they control the ability to turn on and off remotely??? It was working before they had me do this! HELP! And Thanks!
Was this helpful?
Yes
No
Solution #22
posted on Mar 16, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i went to the menu and searched for a network and found cingular..... but i can only call, how can i get txt messaging to work... it just says sim card is not ready yet. please wait... how can i get it to work?
Popular Solutions for T-Mobile Sidekick II
Questions and Unsolved Problems for T-Mobile Sidekick II
Do you recommend T-Mobile Sidekick II?
Answer
Answer
I can't connect.It says"no connection".T-Mobile is not good and I already lost connection.
Answer
Hi, I have a T-Mobile, Sidekick II. So...i live in Brazil. I bought it unlocked, but i can do any... (More)
Answer
Have Sidekick Program Files of Names and Addresses on USB Flashdrive using an .shs file format, want... (More)
Answer
where can u insert a mini micro SD card on sidekick 2?
Answer
battery dies and once I charge it all my pictures and some phone numbers are gone.
17 Other Users Have The Same Problem - Continued
Comment by da-cubanita, posted on Jan 13, 2009
i have a sidekick id that i want to connect with metro but first i need tounlock it
Comment by MSHONESTBKOO, posted on Dec 28, 2008
WEL MY PHONE WONT TURN ON I HAD IT CHARGING AND I CHANGED THE BATTERY BKUT IT STILL IS NOT WORKING WHAT SHOULD I DO??????
Comment by Guest, posted on Dec 27, 2008
Also bought T-mobile off Ebay for interanaional use and it was provided with a "Turbo Sim" (wafer with chip to slide under existing international sim card.) It does not work.
Any one have any unlocking software or codes for T-mobile phones??
Please help
Comment by pink_jane03, posted on Dec 21, 2008
what is/are the special code?
Comment by MamaChenet08, posted on Oct 06, 2008
i bought my t-mobile sidekick 2 of the ebay and it was supposed to already be unlocked and it isnt...i need a step my step and a code so i know how to unlock it...please help i dont want to have wasted all this money
Comment by mari_fer17, posted on Aug 14, 2008
hi i need an unlock code!!!!!!!!!! help me!!!!!!!!!! i really need it!!!!!!!
Comment by Guest, posted on Aug 13, 2008
how do i unlock this thing?
Comment by PR_CHULA, posted on Aug 01, 2008
i need to unlock my sidekick ID, the t-moble store didnt help at all. and i need the phone right away .. plzz can some one help me =[
Comment by Guest, posted on Jul 21, 2008
i forgot my code and i need to find out a wat to unlock the device
Comment by Guest, posted on Apr 10, 2008
My sidekick id won't unlock
Comment by Guest, posted on Apr 07, 2008
IT SAYS YOU NEED A 3 DIGIT CODE
Comment by callen24, posted on Mar 05, 2008
i unlocked my sidekick id and my text isnt working
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For T-Mobile Sidekick II:
Top PDA Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
