Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Why is my hoover getting too hot and stopping
I have replaced the filter the hoover works great lots of suction but keeps cutting out when it gets hot...why is it getting so hot..
  • 3 Answers
SOURCE: No suction
I had a a low suction problem. Mine was easily fixed. Stand in front of the machine. When you remove the recovery tank there are the notches on the front of the tank that fit down into the machine. In the right hole in which the right notch fits, there should be a black rubber washer on the machine. Mine somehow came off and feel into the machine therefore there was practically no suction as the seal was not airtight. I only discovered this when I took apart the machine and found it floating around. Just something to check.
Posted on Aug 04, 2007
reddevil6
  • 1673 Answers
SOURCE: Hoover Wind Tunnel Upright Self-Propelled
If you have suction at the hose, then the problem has to down below. Maybe the inlet is clogged. The belts may look ok, but I am sure they have stretched and aren't moving the brush roll under load like it should. The idler has to do with in the carpet setting, it puts tension on the "V" belt so the brush roll will turn and in the floor setting it will roll doesn't turn.
Posted on Feb 11, 2008
SOURCE: Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Posted on Mar 18, 2008
  • 294 Answers
SOURCE: Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Posted on Jan 17, 2009
  • 75 Answers
SOURCE: DC25 Overheating after a filter cleaning
you need to not use this until you get it fixed at a vacuum store.they can probably help you with it.might be there is a short or a little water got on the motor.
Posted on Jun 29, 2009
The make of our hoover is solec ci 1600w it has lossed suction, has got noisey, and cuts out when it gets hot
Here is a link to the hoover site where the manuals are. My guess is that either your filter is dirty or you have an obstruction in your hose or head and it needs cleared which the manual should guide you to resolve. I was unable to find the model you have by your description but you should be able to as the search function will guide you to enter the necessary information to get you where you need to be. Best of luck
Product Manual Search
Aug 28, 2016 | Hoover Vacuums
Just stops working during hoovering
Hi, it sounds that you may have a fault in your cable sometimes the wire inside the cable gets broken and only connects now and again when in the right position. I remember reading some where about this person had a dyson and had to get the wire changed for a second time as this was the fault. They put it into a dyson repairer to get the job done as you have to remove the motor. I no that's what you need to do on a dc07 animal. If its not the cable then it could be the temp cut out switch my first motor would go for so long hoovering then just stop and you would have to wait till it had cooled down then it would go for another short time. I had to get a new motor that time but it was covered by dyson . When the dyson man arrived i told him it was cutting out and he just fitted a new motor. I have since just replaced that motor myself rather than buy a new dyson. Always remember to remove the plug from the socket when doing repairs to your hoover.
Feb 20, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Turn vacuum on it run for a few seconds then stops power on light is blinking
Whats your model number? A lot of machines contain a circuit that cuts the motor power when it gets to hot. Try cleaning/replacing filters and a fresh bag.
Dec 17, 2013 | Hoover Vacuums
I have the same problem as discussed above. My Hoover Pet Cyclonic upright stops working while using it. The bottom feels hot when this happens. When it first occurred, I emptied the canister and even...
The vacuum is probably getting hot and the thermal sensor in the motor is shutting it off and then allowing it to come back on after it cools down. You mentioned replacing the secondary filters, replace the exhaust filter too.
If replacing all the filters did not solve it you may have a clog or restriction somewhere causing the loss of suction and the overheating.
Mar 09, 2017 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
My vax hoover performance 2200 keeps overheating and cutting out after only 10 minutes
mine too.. I got local place to do a deep clean (sic) of all the filters but its made little difference. Hardly does a room before cutting out and then you have to wait an hour for it to cool down. am veryy disapointed
Jul 04, 2010 | VAX Appliances 2000 Canister Vacuum
Wont suction the water
the suction channel is probably clogged.the suction channel goes right up the middle ,you can see it by looking through the cover.probably a lot of hair and dirt stuck up inside.there are some screws on the botton you need to take out then the cover will come off.seperate the 2 pieces of plastic and you will be able to clean the channel.please leave feedback
Apr 05, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Suction hose
i would first double check the hose, remove it and drop a marble through it to be sure. make sure the bag is new and also check the filter underneath the bag if it is clogged it could cut the suction.
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
1,072 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
