Question about Casio G-Shock GW500A-1V Wrist Watch
Setting time Can't set time manualy
  • 5 more comments
  • davidbradley Nov 10, 2007
    How do I reset the time on my G-shock DW-6900
  • Anonymous Jan 16, 2008
    Can't set time on Casio G Shock GW 530A. When switching time zones will not set on NYC Time (EST) Jumps from CHI (CST) to CCS (EST +1)
    Bill Hunt Miami FL
    Tried the other fix, but can't get seconds to flash when pushing Adjust.
  • scottymilly Feb 14, 2008
    cant set time or day
  • Anonymous Mar 10, 2008
    I have a timex 144D sports watch and I have no idea of how to change the time on it.
  • Anonymous Mar 25, 2008
    i need instructions on how to set the watch
  • theo han Mar 25, 2008
    i need to know how to set the watch
  • Anonymous Mar 08, 2009
    i have a GW-500A g shock watch i cannot figure out how to set the time back one hour?
Push adjust.seconds will flash.then push mode until hour split/reset to go down press start/stop to go mode again for minutes and follow step 3.then press adjust to end.
Posted on Nov 10, 2007
I suggest you email them direct for this and also for the manual at but it does sound like you have it and look at # 2, after setting the day, you set the time:
2. Time Setting 2.1 After setting the day of the week, hour display flashes to indicate setting time can be started 2.2 Press +Button to increase number of hour, or Button to reduce hour. 2.3 Press +/ Button once will increase or reduce each hour slowly. To press and hold the button, the hour display moves quickly. Release the button until your desired hour shown on the display. Press SET Button to confirm your setting. 2.4 “Minute” display then flashes to indicate setting minute is ready. Repeat the same procedures in setting hour as in #2.2 and #2.3 to set minutes.
manual here:,d.cWw
Apr 29, 2016 | Watches
How to set the time on an adidas sports watch ADP6034
In time mode, press and hold A for 2 seconds to enter time setting.
Press C to increase setting value. Press D to decrease setting value.
Press B to enter next setting field.
Press pusher A to exit setting mode.
From Left top button A and following B & right top C & D bottom.
Dec 27, 2012 | Watches
How to set clock
10 Half Digit Digital FL145, FL186
Normal Time Display
1. Press A to change mode.
2. Press B for EL.
3. Press C to toggle 12/24 hour format.
4. Press D to stop alarm sound.
Time/Calendar Setting
1. From normal time display, press A three times to enter setting mode. Seconds will begin flashing.
2. Press C to reset seconds to zero.
3. Press D to set and advance to next setting value.
4. Press C to increase digit; press and hold C for fast advance. Press D to set each setting value.
5. Setting sequence is: seconds, hour, minutes, month, date, day of week.
6. Press A to exit setting mode.
Alarm Setting
1. Press A to change to alarm mode (AL).
2. Press and hold C for alarm sound testing.
3. Press C to toggle alarm/chime on/off.
4. Press D to enter setting mode; hour will begin flashing.
5. Press C to advance digit; press and hold C for fast advance.
6. Press D to set hour and minutes.
7. Setting will automatically exit setting mode mode after minutes are set.
Chronograph Mode
1. Press A to change to chronograph mode (ST).
2. Press C to start/stop chronograph.
3. Press D to reset chronograph when it is not running.
Split Time
1. Press D while the chronograph is running.
2. Press D again to return to the chronograph.
3. Press C to finalize timing.
4. Press D to reset to zero.
Mar 29, 2012 | Fossil Fuel Josh JR9120 Watch
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
After you unscrew the crown it is already in winding position. If you pull the crown, it will go to the date setting position. Further pull of crown will set it in time setting position. Try to pull the crown till you get it in correct date setting position and change the desired date. Do not use the date setting between 10pm - 2am, as this can damage date mechanism. The best way is to pull out crown to the time setting position and set the time to 6.30(anytime) and then push the crown in to date setting position and change the date to the previous day's date. Then again pull the crown out to the time setting position and advance hands forwards (clock wise) till hands pass 12.00 (midnight) and the date changes automatically to the desired one, then adjust the time, push the crown fully in and screw the crown on.
Jun 01, 2011 | Rolex Lady Datejust 179173SRJ Watch for...
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
I just bought a watch its number is ADH4017 i believe its the peach tree watch,something like that. its neon yellow, anyway i cant find the settings to change the time. can somebody please help me i...
1. In normal time display, press and hold A to enter setting mode; chime will begin
2. Press C to increase setting value. Press D to decrease setting value.
3. Press B to set and advance to next setting value.
4. Setting sequence is chime, 12/24-hour time, hour, minute, second, year, month,
date, Auto EL.
5. Press A to save data and exit setting mode.
Dec 02, 2010 | Adidas Unisex Watch Wooster ADH1770 - WW
How do you set this watch....4 buttons
[L1] [R1]
[L2] [R2]
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
Jul 26, 2010 | Fossil JR9455 Watch
How do i set the analog time manualy this a casio wave cepter watch model wva 106ha
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "".
Select "support" and the "manuals",
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 28, 2010 | Watches
Casio G-Shock GW500A-1V Wrist Watch Logo
698 people viewed this question
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
