Question about Sport & Outdoor - Others
Outboard Suzuki DT200 -87 has no power
Hello, I have had this engine for 6years and day before yesterday it happened. Only three guys on boat, full throttle and engine took only <3000rpm(normal about 5000rpm). I made it to shore. I changed the filters and looked that plugs were fine. Yesterday a new try, again same effect except the engine stalled completely and didn't start again(three hours of engine checking on lake). I had to paddle my way to shore.
I again changed the filters, looked that fuel is coming to engine, change the spark plugs and caps. Now it starts, but when trying to load the engine running it against ropes on pier, it stalls right away. Idle is fine and in neutral position engine takes over 5000rpm. When trying the to load the engine with reverse, it works fine. Runs about 2000rpms with full throttle=>should it run faster? I affraid going on lake if I cant first succesfully load the engine on pier.
Any tips how to proceed?
  • 41 Answers
SOURCE: 1996 bayou runs for short time ,keeps stalling out
Hello, I would start first, make sure ex pipe is open . Then I would check the pick up coil, ohms should be 390-590 on a 300 KLF. Do this test before u start the bike Then start the bike and when it quits running check the pick up coil ohms. If good move on to the coil, If good then I would say good chance CDI is bad I hope this helps
Posted on Nov 26, 2008
  • 7 Answers
SOURCE: Hard starting when cold, runs rough at idle and any steady speed.
Your carburetors need to be cleaned. The pilot jets are at least partially plugged.
If you are comfortable doing this yourself, you need to remove the seats, fuel tank, and air induction system before you will be able to get the carbs out. Be carefull when removing the fuel tank, there is a wire harness that will need to be un plugged from it to remove it. The wire harness plug runs under the plastic tray under the seat. There are 3 plastic rivits that will need to be removed to get to the plug. The carbs come out as a pair, and can be tough to get back in the boots.
You need to remove the float bowls, remove the jets, and blow carb cleaner and compressed air through them all. The pilot jets are most likely the only culprit, but you might as well clean everything if your going to all the trouble. You should also blow carb cleaner and compressed air through all of the other passages while your at it. Make sure that you can see through the jets and there is no debris left in them. Make sure to clean the floats, needle valves, and float bowls as well.
Then re-assemble
This happens when the bike sits for long periods. The fuel we get now days has a very short shelf life before it goes bad. Fuel oxydizes over time, and it happens even faster in a small amount that is vented which is exactly as it is when its in the carburetors of a motorcycle. When fuel oxydizes and evaporates, it leaves a gummy mess behind. The pilot jets are the smallest passages that sit in the fuel, so they naturally plug first.
You can prevent this by keeping fuel stabilizer in your fuel when ever the bike will be sitting for long periods of time. Myself personally, when I store one for the winter, I like to leave the carbs empty.
SOURCE: I have a 1987 mercury 9.9 outboard drive problems
the inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Posted on Apr 23, 2009
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
  • 69 Answers
SOURCE: 00 Cavalier won't stay running.
need to have it scanned to see what codes it has but sounds like a security system problem factory or add on if key has chip in it security prob very likely.hope i helped
Posted on Jul 06, 2009
We have an old not sure how old suzuki 14 hp outboard which does not have a kill cord . Can we retro fit ? Thanks
Symply replace the actual engine stop switch with a kill cord type.
Every Suzuki model should fit...
Aug 12, 2017 | Suzuki Boating
Hi, have a mariner 75hp outboard serial number 9502368. Can you please identify year and model so I can order spares
Hey Arthur,
These guys will take care of you,,, that serial number doesn't satisfy the rewquirements for a search...? They will need more info.. more numbers on any plate..freeze plug..look around the outside of the engine carefully..
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 19, 2017 | Boating
My boat reaches full speed 12 mph at half throttle any thing after that it just revs up and actually goes slower 1st I thought I had a spun hub but I replaced it with a brand new hub kit and prop
Sounds like 'cavition' Michael. Google it.
Don't run it for any length of time because your engine is over-revving with no load. Adjusting the trim usually fixes it, or accelerating gently rather than a fist full of throttle.
May 16, 2016 | Boating
Water in the oil of my 4 cycle Suzuki boat motor, what could that be
without a model number its impossible to tell weather you have a oil/sealed water/water heat exchanger or water is directly circ thru block , if its the latter 4 sure you have a bad head gasket ( Happens on aluminum block) if its the first one id 1st ck the heat exchanger O ring seals
Nov 13, 2015 | Light Outboard Motor Boat Bass Fishing...
Why can't I get full throttle unless I hold choke in?
The fishing boat doesn't have a choke - throttle. But its unknown engine may have it.
Aug 21, 2015 | Boating
Engine runs idles great slow speed until throttle up then shuts down
Depending on where you are, you could be getting carbeurettor ice. It's rare, but has happened to me with a 35hp outboard in early morning when temp was just above freezing but humidity was high.
May 20, 2015 | Boating
Sport & Outdoor - Others Logo
551 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
