Question about Logitech Harmony 880 LCD Remote Control
Sound adjustment doesn't work to get louder, only softer
Remote is getting older and it seems like we have worn out the volume control. We can push the - and get softer, but the + to get louder works only sporadically. Is it possible we've worn it out and have to get a new one or can it be fixed? If it can be fixed, what do I do?
    President:
  • 1,348 Answers
Take it apart.on the back of the push buttons there is a graphite coating.sometimes oil gets on it and it won't work properly.clean the pc board gold contact areas and the back of the carbon buttons.if the carbon is worn off,cut a small piece of foil 1/8 inch in diameter,and glue it to the back of the button. that will make contact with the pc board foil to make it work.
Posted on Jul 03, 2009
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
How do i control volume louder or softer
hello,
There is no volume control from DVD-C350 , only sound output. If you want to cotrol it, you must add a amplifier.
Apr 09, 2011 | Samsung DVD-C350 DVD Player
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do you turn the sound up on the Motorola H505
The volume controls are on the left and right of the headset.
You push one to make it louder and the other to make it softer (see diagram below).
Hope this helps!
Jun 01, 2010 | Motorola Mobility H505 BLUETOOTH HEADSET
I need a volume pedal for a SX KN6000 Technics keyboard
As there's no polarity switch on the FC7 the quick and dirty way is to cut the cable and swap the wires around.
Feb 18, 2009 | Music
SA-AK95 volume control problem
This volume controls is actually what is called an encoder. The control itself needs to be replaced. Figure on $5-$10 for the part plus the local labor rate for the total repair cost.
Dan
May 01, 2008 | Panasonic SC-AK75 Shelf System
Logitech Harmony 880 LCD Remote Control Logo
409 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
