Question about Clarion DC625 6-Disc CD Changer
My car 6 disc cd player in stuck with more than 6 cd, and i dismantle it to remove the cds cuz eject and load didnt work. but after removing the cds, the cd player still stay stuck. What to do to get my 6 disc cd player playing again. car 6 disc music player Marc: Clarion model: ps-2998 D-A serie: 0003653
Eagleeyes
  • 199 Answers
SOURCE: Clarion CDC1235 CD Changer
hi Its Error 6 no focus. could be dirty cds. dirty laser. or faulty laser. regards Mark www.carradiospares.co.uk
Posted on May 03, 2007
SOURCE: clarion 6 cd changer cassette will not eject
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Posted on Apr 17, 2009
SOURCE: no ejection
i had the same problem and just solved it. I had a CD jammed in the player and so it would not play and would not eject.
You have to take the entire outside protective case off. (about 10 little screws). Carefully remove the entire case metal case including the black plastic face plate. Look just where the magazine meets the player and you will see a little white tab/button. I pushed this and heard a click. I then hooked the player up to power (with putting the case back on yet) and the CD returned to the magazine. I then pushed eject and the magazine came out. I then reassembled and remounted the player, seem to work fine now.
Posted on Jul 17, 2009
Danniboi
  • 1098 Answers
SOURCE: magazine not ejecting when press eject button
Sounds like a fuse, if not then the motor to eject is not working, you can fix these yourself easy to open up and identify the fault.
Hope this helps
Regards
Dan
Posted on Feb 01, 2010
SOURCE: I had a Clarion 6 Disc CAA-355 in my car which got
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
Posted on May 31, 2010
CD PLAYER NOT WORKING MAZDA RX8 2004
It is likely that a CD is stuck in transit between the magazine and the player mechanism. It may be necessary to remove the radio and disassemble it enough to get the CD back into its magazine slot and allow removal of the magazine.
Mar 30, 2014 | Mazda RX-8 Cars & Trucks
2007 Toyota Yaris Stereo Won't Eject CDs
you may have to use needle nose pliers to pull them out or remove the radio and open it up and remove them also take a look at the drive belt it may have broke, there are many electrionic places that will repair it if you remove it and take it to them, most of the one i run into broke a belt or 2cds were jamed inside it.
Mar 01, 2010 | 2007 Toyota Yaris
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
JBL 6 CD AM/FM Cassette Audio has CDs stuck inside and won't play or eject them. How can I get them out?
I've had this happen before with car stereo's uh i just normally unscrew the screws out of the top of the player to where you can get to the tray or slot for the cds and force the cd tray or the cd itself out but be careful and not break the cd this might work it usually does for me
Aug 17, 2009 | JBL MCDC100 6-Disc CD Changer
Cant play dvd cd or even eject the disc that is already in .
actually it is due to faulty disk or dirty lens sometimes , when the lens is dirty it keeps on trying to read the data from cd or dvd and it just cant stop that infact stuck in it , or the other reason is faulty loading gear , in either case u have to physically dis assemble the player , remove the top cover some 4 or 6 screws are there in place open the top cover see the cd /or dvd and remove it physically do not force anything hard when removing the media and then if u can see the lens of ur player just clean it with a soft cloth with ur fingers in cicular motions very gently and u will see that it will play dvd /cd fine , the other thing if the loading gear is faulty or broken then u can ask me more on this
Pls rate me WELL !
Jul 04, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Toyota dashboard CD player won't eject
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
Oct 04, 2007 | 2003 Toyota Celica
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Clarion DC625 6-Disc CD Changer Logo
486 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
